Go to Post Eription- the condition of shredding the eardrum from excessive cheering at robot competitions - Wayne C. [more]
Unread 26-01-2008, 10:09
Laxphan1525's Avatar
Laxphan1525 Laxphan1525 is offline
AKA: Harrison
FRC #1525 (Warbots)
Laxphan1525 is an unknown quantity at this point
Re: How would you machine this?
Originally Posted by fstumpo View Post
You might look at this link. I am not suggesting using this but, it is designed for a table saw to cut aluminum
http://justsawblades.com/systimatic/hsr_gold.htm
that blade is not for a table saw so esstentially your just using a radial arm saw or a miter saw as a chopsaw why do that when they have saws specifically made for metal called a chop saw.
Unread 26-01-2008, 10:17
AKA: Harrison
FRC #1525 (Warbots)
Originally Posted by maclaren View Post
Its not a very good Idea to use an abrasive blade to cut aluminum. There are carbide tipped blades that are specifically meant to cut aluminum and other non-ferrous metals. Here is a link to the blade that I'm talking about.Non-Ferrous Metal Saw Blade
I've been machining working with aluminum for five years now. Never once have i had a problem with an abrasive cutting wheel they work great. If ihad the money to spend the 460 to 540 bucks to buy a carbide tipped blade and dry cut saw i would but if your going to spend that kind of money on a saw you mind as well spend the 2000 and buy a nice wet saw which is the ultimate solution.
So how would you fix this year's game? AnonymousMan General Forum 6 09-01-2005 09:36
How much would you pay - Championship? Steve W General Forum 2 03-06-2004 19:20
How much would you pay - Regionals? Steve W General Forum 10 03-06-2004 19:18
Would you like to learn how to sign? OneAngryDaisy General Forum 0 05-03-2003 20:11
Buckeye Regional: How would you judge? Wayne Doenges Regional Competitions 6 21-03-2002 21:33
