Go to Post I decided I would keep coming and it just kept getting more and more fun. By the time build season started going I couldn't have quit if I wanted to ^_^ - Mr. Pockets [more]
Unread 26-01-2008, 10:38
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
pneumatic cylinder help.
Were trying to figure out these pneumatics and we can't figure out what kind of cylinder to use. Retracted, we want it to be 8 to 10 inches. We want to use it for our scissor lift, and that means a 2-way one, without the springs. (Ive never done anything with pneumatics before, so if I sound dumb, sorry ) So.....what would be the best one from this page:
http://www.mcmaster.com/
Eh...theres no link to the page. Go there and type in pneumatics.
Thanks for the help,
2495
Unread 26-01-2008, 10:46
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pneumatic cylinder help.
Unfortunately, you cannot use any of the cylinders that they sell, as far as I know.
You need to read this manual
http://www.usfirst.org/uploadedFiles...ics_Manual.pdf
and go to the Bimba FIRST page
http://www.bimba.com/FirstFree.aspx
and order your 3 free cylinders there, and if you need more cylinders they need to be exactly what is listed on that page.
Also if you only have 8 to 10 inches for it in the retracted position, you won't get much travel at all, especially with the large bore cylinders that can actually push with a lot of force.
Unread 26-01-2008, 10:55
esisso esisso is offline
AKA: Eitan
FRC #1242 (Team Smiley)
esisso will become famous soon enough
Send a message via AIM to esisso Send a message via MSN to esisso
I think what you mean by the two way one is one that will stay open or stay closed.....for this configuration you'll need a double solenoid (provided in the KoP) hooked up to your cylinder instead of a single solenoid. Moving on from that, bimba ofers 3 free cylinders every year to teams....it might be to late to order but give it a shot, the link to that page was posted farther above.
When ordering your cylinder keep in mind that stroke is how far it reaches, so if u want 8 inches of displacement get an 8 inch stroke. Bore is the thickness of the piston, the thicker the more force behind the cylinder.
Good luck!
Pneumatic Cylinder yanksrock777 Technical Discussion 2 20-02-2007 11:01
Pneumatic cylinder size bruss6 Pneumatics 8 16-02-2007 16:37
pneumatic cylinder part numbers Ed Crammond Pneumatics 0 14-02-2003 19:27
Pneumatic Cylinder Length billy Technical Discussion 2 10-01-2003 08:30
2" Pneumatic Cylinder Posted Ed Sparks General Forum 0 27-01-2002 15:47
