Re: pic: shaft
Looks like a nice shaft..from the left of the damage. Is that 6061, 7075, or 7068?
Do the Outbacks come with that Aluminum shaft or did you just make it yourself? If they came with, then they seem to be the Banebots of last year. ![]() |
Re: pic: shaft
The shaft came from the Outbacks we bought last year and are using as a practice bot, didn't know they were aluminum until a few days ago. I would never use aluminum axles
Re: pic: shaft
I wouldn't look at this as a testament to why steel is better. I'd look at it as a prime example of what happens when you choose the wrong alloy material for a high stress application. Many teams have been using aluminum shafts with great success. There really is no reason to use steel, if you have the proper machining resources to make your own shafts out of Al. |
Re: pic: shaft
6061 isn't a great alloy for transmitting torque through keyways or such things with high stress concentration factors. 696 used 1/2" axles with 1/8" keyways out of 2024 Aluminum (McMaster pre-keyed stock) last year with 5" wheels geared for 9fps with two CIMs on each side and never had a problem with them over two regionals and championship. But 6061, I doubt it would have survived.
Another important thing is to make sure your key fits tightly with no backlash. |
Looks like the key was shorter than the keyway, which would halve the load the keywayt would be able to withstand. Was that the case?
| pic: Shaft Drive Bearing Blocks | MAteo9944 | Extra Discussion | 25 | 01-01-2007 11:22 |
| pic: Top View of Shaft Drive | MAteo9944 | Extra Discussion | 2 | 30-12-2006 20:59 |
| pic: The Infamous Shorn Shaft of PARC VII | CD47-Bot | Extra Discussion | 11 | 12-05-2004 18:08 |
| shaft drive | Joseph F | Technical Discussion | 5 | 03-02-2002 17:51 |
| Big Shaft to Little Shaft? | Anton Abaya | Technical Discussion | 7 | 21-01-2002 19:27 |
