Go to Post *When putting grease on anything* "The bigger the glob the better the job." - TheMagicPenguin [more]
Unread 26-01-2008, 12:02
jacobevelyn jacobevelyn is offline
FRC #0639
jacobevelyn is an unknown quantity at this point
Cool Controller Board
Does anyone know if it's legal to have AA (or other) batteries to power LEDs on the control board? The LEDs would have no practical usage, and be just for show.
On the same note, where are the rules for the control board? I can't find them on the FIRST website...
Unread 26-01-2008, 12:04
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Re: Cool Controller Board
No, you must use the OI's power if you wish to power anything. The only exception is the chicklet.
I change my opinion after closely reading the manual. You can connect LEDs as long as they do not connect to the joystick ports:
<R105> All equipment connected to the joystick ports of the Operator Interface must be powered
solely through the power available through the port. External power sources of any type are
not permitted on any equipment connected to the joystick ports. Portable computing devices
must not be connected to joystick input ports on the Operator Interface. Power-passive
devices (e.g. joysticks that draw their power solely through the Operator Interface joystick
port) are permitted.
<R106> Devices connected to the joystick ports of the Operator Interface via a FIRST-approved
USB adapter (the only approved USB adapter is IFI Part Number USB-CHICKLET) are
excluded from Rule <R105>. If used, this USB adapter must be powered with a 7.2V battery
functionally identical to the back-up battery. Power from the competition port or any other
source shall not be used to power the USB adapter. The USB adapter must be positioned
within the OPERATOR CONS
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 26-01-2008, 12:33
edgar_amaro edgar_amaro is offline
FRC #2582 (Pantherbots)
Team Role: Student
edgar_amaro is on a distinguished road
What about LED ligths on the Robot ???
Unread 26-01-2008, 13:13
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
One year we had lights on our OI and they were considered against the rules because they /could/ interfere with the camera.
Amperage Robotics Team 1225
Site under-going revamp. :/
Drawing of the controller board Team 2480 Electrical 3 17-01-2008 14:17
pic: Team 1872's controller board Armando Gonzalez Extra Discussion 8 15-02-2007 13:30
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Using Custom Inputs on the Controller Board schenkin Programming 10 27-01-2005 10:26
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
