Go to Post ...and then at the end they interviewed this 5 year old on his favorite part (of the fair): "I liked the robot" - Jessica Boucher [more]
Unread 26-01-2008, 14:09
Stobei Stobei is offline
FRC #2035
Stobei is an unknown quantity at this point
away around the USB chicklet for using USB Controllers
Hello everyone
I had an idea for Not have to buy the chicklet to use a 360 or any usb Controller.
What if you used a 15 pin addapet to usb (male) and then used a Female to Female Adaptor (type A) would that work or is the there a rule where we must use the chicklet?
Unread 26-01-2008, 14:16
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: away around the USB chicklet for using USB Controllers
Typical 15pin->USB converters simply lack the capability to turn a digital USB signal back into analog signals that the OI can understand.
The USB Chicklet is the only device that does that, as it acts as a USB host.
Unread 26-01-2008, 14:27
The Lucas's Avatar
CaMOElot, it is a silly place
Also read <R105> and <R106>, the usb chicklet is the only device with exemption from the external power rule. You can however rewire the Xbox controller yourself to fit the joystick port.
Robot Inspector
Using the USB Chicklet with a steering wheel PhilBot Control System 16 13-01-2008 11:43
Gameport to Usb cable vrs. Usb Chicklet haywirerobotics Control System 4 25-01-2007 19:03
Does EasyC Pro work with the USB-Chicklet? lightning_blast Programming 6 20-01-2007 23:39
Ideas for using the NI USB-6009 DAQ device Andrew Schuetze National Instruments LabVIEW and Data Acquisition 0 05-01-2006 22:55
USB and Mac Support for IFI FRC Controllers??? RIgnazio Rumor Mill 26 23-09-2005 17:31
