Go to Post Isn't the professional level for us called a job? - CalTran [more]
Unread 26-01-2008, 14:16
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: away around the USB chicklet for using USB Controllers
Typical 15pin->USB converters simply lack the capability to turn a digital USB signal back into analog signals that the OI can understand.
The USB Chicklet is the only device that does that, as it acts as a USB host.
Using the USB Chicklet with a steering wheel PhilBot Control System 16 13-01-2008 11:43
Gameport to Usb cable vrs. Usb Chicklet haywirerobotics Control System 4 25-01-2007 19:03
Does EasyC Pro work with the USB-Chicklet? lightning_blast Programming 6 20-01-2007 23:39
Ideas for using the NI USB-6009 DAQ device Andrew Schuetze National Instruments LabVIEW and Data Acquisition 0 05-01-2006 22:55
USB and Mac Support for IFI FRC Controllers??? RIgnazio Rumor Mill 26 23-09-2005 17:31
