Go to Post Sounds fun? Maybe only if you're a giant dork, but I'm a pretty giant dork, so... - Madison [more]
Unread 26-01-2008, 10:54
hysqrd hysqrd is offline
FRC #0231
hysqrd is an unknown quantity at this point
Mechanum Programming for One Joystick
Hello anyone and everyone!!! I have been searching Chief Delphi endlessly for Mechanum code for one joystick, but I've come up empty-handed. This year our team wants to implement a mechanum drive train, but I am not that knowledable about programming C to come up with it on my own so my programming team and I are in need of some help could anyone link us to or provide some code possibly? Thanks for all your help!!!
Unread 26-01-2008, 11:15
Lucretius Lucretius is offline
#395 Mentor, #1884 Alumnus
FRC #0395 (2 Train Robotics)
Lucretius is an unknown quantity at this point
Re: Mechanum Programming for One Joystick
See 357's Jester Drive code: http://www.chiefdelphi.com/forums/sh...ht=jesterdrive
Everything's correct, it's just spread out so the final equations are just plain addition instead of mystery plusses and minuses (due to vector addition).
Unread 26-01-2008, 11:40
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Some functions you want out of a mecanum platform are forward and lateral translation, along with rotation. Most single joysticks don't have 3 axes, unless you can find one with twist, so you can rotate.
Last year, we looked at 190's code for where to start. Good luck with yours!
Unread 26-01-2008, 12:27
GRS GRS is offline
FRC #1764
GRS is an unknown quantity at this point
Take a look at the vectors for mecanums, they should point in an x direction (opposite each other), and in a y direction (also opposite).
It should just be a simple matter of pwm assignements.
Unread 26-01-2008, 14:29
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
See this Chief Delphi thread about mecanum drive:
http://www.chiefdelphi.com/forums/sh...ad.php?t=61482
If you still need help, just reply with a question.
Unread 26-01-2008, 15:21
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
Does your joystick rotate too? Might be a good idea to have a separate control for that. We used a potentiometer with a record mounted on it as a turntable last year
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 26-01-2008, 21:58
Last year, we originally had a joystick that twisted (for the z-axis of mecanum drive). But after experiencing lots of problems (namely, it was too difficult to achieve fine control over the short twisting range of the joystick), we swapped twisting out to a second joystick.
Unread 14-02-2008, 13:05
FRC #0231
Thanks for all of your input!! Now, we've decided to go with a tank drive on one joystick and the crab/strafing action on the other...but I am still having difficulties programming that....
Unread 14-02-2008, 13:21
RyanW RyanW is offline
RyanW has a spectacular aura aboutRyanW has a spectacular aura about
If by "Tank drive" you mean moving straight and turning, any of the Mecanum Drive codes already posted should still work...just set the forward and turn inputs to the first joystick, and the strafe input to the other one.
Joystick Programming team 803 Programming 6 21-02-2006 11:49
One Joystick Drive mattsavela Programming 20 19-05-2005 21:28
One Joystick Control KWalsh Programming 4 24-02-2004 17:53
More than one joystick from one port Jmoo Programming 3 26-06-2003 18:01
One Joystick Code fs_2002 Technical Discussion 3 16-01-2002 00:47
