Go to Post Holonomic? I thought we were holographic. Or was that autonomic? I'm confused.... - Wayne C. [more]
Unread 26-01-2008, 13:50
wkethman wkethman is offline
Team 118 Former Member
AKA: William Kethman
None #0118 (Robonauts)
wkethman is on a distinguished road
Send a message via AIM to wkethman
Gyro Heading Correction in Operator Mode
If you set up 4 wheel tank drive in Operator Mode as shown:
void OperatorControl(void)
Arcade4(PORT_1, X_AXIS, PORT_1, Y_AXIS, 0, 2, 1, 3, 0, 0, 0, 0);
Is there (1) anymore that you have to do if you are just trying to simply drive the robot with one joystick as defined?,(2) can you embed the gyro heading correction?, (3) and is there more information or guidance that you can give for pneumatic control. Thank you
Unread 26-01-2008, 15:25
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Gyro Heading Correction in Operator Mode
That's close to it. Each time Arcard4 (or any of those functions) is called it gets one set of joystick data and passes it to the motors. So you need to put your code into a loop to repeatedly read the joysticks and set the motors.
     while (1)
           Arcade4(...);
           // put other motor/OI control code here
On the gyro subject, it depends on exactly what you want the robot to do. This code is driving based on the joystick. What sort of heading correction did you have in mind?
And last, pneumatics is actually control is not too bad. Look at the InitPressureSwitch function. It will automatically turn the compressor on and off based on the currrent pressure value from the pressure sensor.
For operating solonoids, look at the SetRelay function.
These are all described in the documentation on the web site.
Brad Miller
Robotics Resource Center
Ever use a helicopter heading hold gyro before? seanwitte Electrical 7 16-01-2008 12:59
Gyro Heading always zero, yet operating? marccenter Programming 3 16-01-2008 10:54
Reading gyro before Autonomous mode Doug Leppard Programming 9 06-01-2008 21:02
Keeping a certain heading using a gyro DanDon Programming 12 08-03-2006 14:27
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
