Re: Broken 2008 RC and IO?
Its been over an hour now since it has worked.
Dashboard works fine through the usb to serial adapter. But I am still having problems with programing it. Last time it stopped working was in the middle of a transfer. This has happened before and i solved the problem by leaving it unpowered for 10 mins or so then re-connecting it. It by default goes into program state and i send it code. Not working this time around. It fails to connect every single time. Its doing this from a PC with a serial port too. I have tried holding the program button down while powering it on, (which turn on only the power led and the program led) and i still have the same problem. I am 100% out of ideas right now - Bochek |
| Prepping for 2008: Awards, Bandsaws, and Perspective | Rich Kressly | General Forum | 16 | 11-02-2008 10:25 |
| CMU and 2008 | King Duke | Programming | 14 | 29-01-2008 21:30 |
| 2008 and drivetrains | Tottanka | Technical Discussion | 67 | 15-01-2008 23:38 |
| <R38> and adhesive backed tape in 2008 | Alan Anderson | Rules/Strategy | 14 | 10-01-2008 19:01 |
| Broken promises or BROKEN ROBOTS! | archiver | 1999 | 9 | 23-06-2002 22:18 |
