Go to Post New CAD computer one day and the 254 Build Blog Tech Binder the next? Christmas in July really does exist. - [more]
Unread 26-01-2008, 21:34
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
Grounding Solenoids / Spikes
As of tonight our robot is up and running. We are launching with pneumatics but between the 12V wire, PWM cables (for the relays) and pneumatic tubing is it starting to look like spagehtti.
To clean some of this up, I was wondering can the pneumatic solenoids can share a common ground?
Unread 26-01-2008, 21:40
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Grounding Solenoids / Spikes
Yes, this is perfectly acceptable.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 26-01-2008, 21:45
7-11,
Under certain conditions the answer is yes. Those conditions are that the power supply returns go back to the common point on the breaker panel or to a common point on the Rockwell block. If you tie several returns together to a common wire (sized appropriately) and that then goes back to one of the common points, that is acceptable as long as it is insulated.
I don't always know what someone has in mind when they ask a question like this. You may not tie the common point to the robot frame/chassis as is common practice for auto electricals.
Power Distribution Block Grounding Karma Electrical 15 22-01-2008 07:18
Spikes 3dude_2231 Programming 3 12-02-2007 16:53
Spikes macwhoo Electrical 5 16-01-2007 19:31
Spikes Denman Control System 17 16-11-2004 07:51
Spikes? st28 Programming 2 24-02-2004 11:36
