Go to Post Maybe we should put one of those advisory signs: "Don't try this at home ... or at Robotics competitions" - Franchesca [more]
Unread 26-01-2008, 20:04
Mentor08 Mentor08 is offline
FRC #1887
Mentor08 is an unknown quantity at this point
Omni wheels?
We are using 4 motors, 4 wheel drive, 2 drive chains per side, 2 high friction aluminum wheels, and 4 omni wheels (2 on left together, 2 on right together). Is it better to put the omni wheels on the front or on the rear?
Unread 26-01-2008, 20:06
Re: Omni wheels?
How about opposite corners?
It would depend on your application, where you want the robot to rotate around, and how easily you want to be turned. Putting them in opposite corners reduces the last factor.
Unread 26-01-2008, 20:07
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: Omni wheels?
That depends on how you want your robot to turn. If you mount the omni's in the rear the robot will pivot on a point directly in between the front wheels. If you mount them in the front it will pivot around a point between the two rear wheels.
In our 2006 robot we used this system and found it hard to steer no matter what the configuration. If I had to make a choice I would say to put the omnis in the rear because this allows (from experience) the most normal steering.
Unread 26-01-2008, 20:19
FRC #1887
Re: Omni wheels?
The opposite corners...hadn't thought of that. I don't think that they are the same diameter.
We used casters on the front last year. Big mistake, no control. My thinking is that omni's on the front might end up being the same with a little more control. Hopefully putting them on the rear will give more control.
Unread 26-01-2008, 20:33
Re: Omni wheels?
Omnis on the front will give you only marginally more control than casters--rear is the way to go.
If you wanted to be in the true engineering spirit then you could build your chassis such that the wheels are interchangeable and then try both varieties.
Unread 26-01-2008, 21:05
FRC #1887
Re: Omni wheels?
Good idea on trying it both ways.
Is it better to use 1 chain per side or 2 chains per side?
Unread 26-01-2008, 21:15
Mark Holschuh's Avatar
Mark Holschuh Mark Holschuh is offline
FRC #2194 (Fondy Fire)
Mark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud of
Re: Omni wheels?
You want to maximize the amount of wrap of the chain around the sprockets to prevent the chains from slipping off. I recommend two chains, one going to the front wheel and one to the back. Make sure that your sprockets are aligned with each other.
"The true sign of intelligence is not knowledge but imagination."
-- Albert Einstein,
"The ultimate test of man's conscience may be his willingness to sacrifice something today for future generations whose words of thanks will not be heard."
- - William Proxmire
Unread 26-01-2008, 21:48
FRC #1887
Re: Omni wheels?
Thanks!
caster wheels vs. omni wheels gondorf Kit & Additional Hardware 4 23-01-2008 22:45
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Omni Wheels edomus General Forum 6 06-02-2004 13:35
Omni Wheels??? Alex Cormier General Forum 1 24-01-2004 18:00
Omni Wheels! jrgrim12 Technical Discussion 5 04-02-2003 16:07
