#9
Re: reusable zip ties
I use these all the time at work. It helps hold wires in the bundle until you are finished with the system. Then you can add permanent ties and remove the others after everything is finished.
| pic: Zip ties man, zip ties! | buss | Extra Discussion | 2 | 09-04-2008 07:14 |
| [FTC]: Zip ties | HRobotics | FIRST Tech Challenge | 9 | 29-11-2007 15:05 |
| Should Zip Ties (Cable Ties) Have a Warning Label? | Wayne C. | General Forum | 38 | 08-11-2007 20:47 |
| Zip ties | tinderfitles | VEX | 2 | 24-10-2006 16:47 |
| Zip Ties | Robot935 | Technical Discussion | 12 | 11-02-2002 10:58 |
