Go to Post I don't mind being odd...I like to - listen - to Dean Kamen's speeches. They make sense. I don't get to listen to a lot of sense in the world, just a lot of noise. - JaneYoung [more]
Unread 26-01-2008, 10:30
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Hooking up a backup battery
I tried searching, to no avail...so my question is, can I just hook up the backup battery to the backup battery to the port, or do I need to hook up the backup battery to a fuse panel? Pictures would be nice, thank you!
Unread 26-01-2008, 11:14
EricVicenti EricVicenti is offline
FRC #0008 (Paly Robotics)
EricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura about
Re: Hooking up a backup battery
Im not at the lab right now, so I can't show you, but the backup battery connects directly to the robot controller. There are ports on there for you to hook it up. The main power to the robot controller goes through a 20amp breaker on your fuse block.
Unread 26-01-2008, 11:36
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
The backup battery connects directly to the controller's 7.2V backup battery terminals.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 26-01-2008, 13:16
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
The above is true. There's an adaptor in the 2008 electronics box that fits onto the terminals for the backup battery on the robot controller. The backup battery can attach to that adaptor.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 26-01-2008, 14:07
GrammarNazi GrammarNazi is offline
FRC #2952
GrammarNazi is on a distinguished road
Send a message via AIM to GrammarNazi
just directly attach it no fuses needed
Unread 26-01-2008, 17:19
Yep.
The reason for the adapter is that sometimes a controller doesn't have the battery block-style terminal. It has the post-style terminals. So you put the adapter on and the battery just plugs right in.
Unread 26-01-2008, 18:26
neoshaakti's Avatar
Thanks for the responses
my question seems pretty bobo in hindsight
Unread 26-01-2008, 22:09
The only bad question is the one that is not asked.
backup battery charger falconmaster Electrical 16 22-01-2008 12:04
Backup Battery Tottanka Electrical 31 06-01-2008 22:41
backup battery carbuff Electrical 1 19-02-2007 08:28
backup battery nirty Electrical 1 08-02-2006 14:40
EEPROM + Backup Battery Ryan Cumings Programming 4 28-02-2004 13:30
