Go to Post I can't wait to be one of those old kids who can say "Yeah, I remember the days before districts." and then watch the kid's eyes widen when I explain the days of regionals.. - rachelholladay [more]
Unread 26-01-2008, 23:09
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
How low do you go?
Well we have ended up with a chassis that is just 3/8" off the floor... Now to just get some electronics done and we should be rolling along!!
Unread 26-01-2008, 23:11
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: How low do you go?
Be careful of that "BUMP" in the center of the field!!
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Will that clear the 1/2 inch bump on the "lane markers"? Looks pretty cool through.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 26-01-2008, 23:21
ctorloey ctorloey is offline
AKA: Dave Luongo
FRC #1153 (Roborebels)
ctorloey has a spectacular aura aboutctorloey has a spectacular aura about
It does look awesome! Did you guys plan on it being so low as part of the design or did it just happen that way? I hope it isn't too low...
Unread 26-01-2008, 23:24
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
we planed in 1" of clearance for the bump so we don't get hung up on that....
Unread 27-01-2008, 00:27
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Our chassis is also low to the ground this year (about 1"). I would warn you that 3/8" is in my mind a very bad idea. Many things fall off robots during competition especially bolts. At 3/8" your robot could be high centered (or damaged) by a 1/4" bolt. Also the 1/2in bump in the center of the field could a major issue--I would recommend that if at all possible you modify your design.
Unread 27-01-2008, 02:03
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I see you're using acetal sprockets. How well do those hold up to competition?
Mentor 2415
Unread 27-01-2008, 05:07
AdamHeard's Avatar
Lead Mentor
I've seen a few teams solely use them in their drivetrain; Out of the few I talked with, only one team had issues. I believe they had Acetal sprockets without metal hubs and cut keyways into that; those keyways eventually failed. The other teams used the metal hubbed ones or attached them with bolts/pins to the wheels in a dead axle application.
Unread 28-01-2008, 02:21
Doug G's Avatar
Coach / Teacher
We're going to come up with a way to get a little more clearance just for precautionary measures.
Acetal sprockets?? We have use them many times before, but usually in a dead axle configuration. This is the first time we've tried it on a live axle. But also it is the first time we have gone with Hex axles. I doubt the Acetal will fail on 1/2" hex. Got to love those DuMont Hex broaches!! We have had them for two years now and finally get to use them
How do you feel about how the Autodesk award winners were decided? R Stephenson Inventor 43 02-06-2007 20:45
Set Default Digital inputs to Low? How? bad Analog value? Generalx5 Programming 11 04-01-2007 18:57
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
How to measure low velocity nobtiba Electrical 28 22-04-2005 05:37
You think we should try doing a grassroots (ie:low tech) version of Ventures? Koko Ed Games/Trivia 1 19-02-2005 09:29
