Go to Post The game is going to be exciting. I want a front row seat and a big box of buttered popcorn. - JaneYoung [more]
  #76   Spotlight this post!
Unread 24-01-2008, 16:58
Re: Are any teams planning on shooting the ball?
Originally Posted by Chaos in a Can View Post
We discovered that one of the large CIMs is more than capable of launching a trackball.
We also discovered that it's more than capable of lifting a small filing cabinet filled with barbell weights into the air...
You mean the minibike motors from last year? The ones that had the odd-shaped front plate and the belting tensioner and the impossible-to-remove pulley?
If so, you should also discover that they are not legal this year, as they are not in the kit.
If you mean the ones from the kit this year (no odd front plate), then you are fine.
  #77   Spotlight this post!
Unread 24-01-2008, 17:08
Chaos in a Can Chaos in a Can is offline
Joel Spadin
FRC #1736 (Robot Casserole)
Chaos in a Can is an unknown quantity at this point
Send a message via MSN to Chaos in a Can
Its one of the ones from this year's kit.
2006 Xerox Creativity Award
2007 General Motors Industrial Design Award
2008 Judges' Award
2009 Chrysler Team Spirit Award
  #78   Spotlight this post!
Unread 24-01-2008, 17:12
OK, whew. I thought (by the reference to "large CIM") that you had used an illegal motor. Typically, the ones this year are just "CIMs" or "small CIMs". "Large CIM" refers to the biggest motor in the kit last year and the year before, which is no longer in the KOP.
  #79   Spotlight this post!
Unread 26-01-2008, 12:28
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
FRC836 Robobees ... shoots and scores!
Name:	FRC836 Robobee Test Shot.jpg
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
  #80   Spotlight this post!
Unread 26-01-2008, 13:38
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Originally Posted by SoJ View Post
We seriously are serious about launching the trackball. We've got our prototype working wonderfully, and we've designed how it's going to work out. All we need to do is fabricate it (of course we'd need to do the robot first) and attatch. Of course, then we still have to hope it works out the same. We're confident.
It would be wrong for the "bomb" squad not to launch a ball.
  #81   Spotlight this post!
Unread 26-01-2008, 13:46
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I just got word from the NERDS in the fab shop, and it sounds like they have achieved success as well! I think they'll be posting a video soon...
  #82   Spotlight this post!
Unread 27-01-2008, 00:00
cgredalertcc cgredalertcc is offline
AKA: Charlie Baxter
FRC #1747 (Harrison Boiler Robotics)
cgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to all
Send a message via AIM to cgredalertcc
We are capturing the ball using a vacuum lifting the ball so that our arm is slightly below the rack and firing the ball over using two back to back 3/4 inch bore by 10 inch stroke cylinders we've had success with shorter stroke but we want to be sure we get it over so we opted for the longest ones. The funny thing is the 3/4's extend way faster than the 1&1/2's and the ball really doesn't require that kind of force so we get a pretty good shot out of it.
  #83   Spotlight this post!
Unread 27-01-2008, 00:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Not surprising at all, the 3/4" bore cylinders hold a lot less volume of air, so they fill much more quickly
  #84   Spotlight this post!
Unread 27-01-2008, 16:35
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
Team 1711 will be hurdling the ball but instead of hurdling it from off the ground we will be grabing the ball and use an arm to lift it about 6 feet high then throw. That way we can continue driving under the over pass without waiting to lower the arm. Pics and video of our robot will soon be posted
  #85   Spotlight this post!
Unread 27-01-2008, 20:56
Éowyn Éowyn is offline
no team ((no team))
Éowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to behold
Holy cats!!
Nice job!
  #86   Spotlight this post!
Unread 27-01-2008, 21:05
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
1024 is perfecting the design for our linear pneumatic launcher. So far, our launcher (which currently resides on a 2x4 wooden frame) can put the ball, repeatably, on the overpass, but not launch it over. So, after when tune the launcher up some more and put it on it's mount (which is about 3' off the ground higher than it is now) it should work fine. It's flight path apexes three feet ahead of the robot.
FYI I used a little calculus to figure out a way to calculate trajectories. If you know how far down range and how far up you want the apex of the ball will be, my equations will tell you how fast and at what angle you have to shoot the ball. If you all are interested, I'll post a scan of my piece of notebook paper.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
  #87   Spotlight this post!
Unread 28-01-2008, 10:46
AKA: Charlie Baxter
What I meant to say was that the result of using the 3/4" cylinders is a faster velocity on the ball after firing. We did some testing using a complete vertical shot on the ball and two 3/4" cylinders made the ball travel higher than two 1&1/2" of the same stroke. Any ideas on increasing the output of the shot. We already made a huge difference by placing storage after the regulator, but before the solenoid. Any advice would be appreciated. We have recognized some friction issues with our linear guide and we are considering switching to one of the micro series linear guides from NSK, because of the benefits of the bearings over the low friction plastic sliders with what we use now. Also we are stiffening the track that the guides ride on, because at current they are only fixed at one position. Adding a second attachment point should reduce some of the binding we see with the single attachment point. Right now we are unreliably shooting over the rack if we aren't lined up perfectly on the rails that are spaced wider. At the 14" points the ball bounces cleanly over.
Thanks, Charlie
  #88   Spotlight this post!
Unread 28-01-2008, 11:01
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
We're lifting instead of launching. I feel like we'll be the odd bot out because of this thread, but whatever. The key to our bot is the ability to capture and irradically bouncing ball while being knocked around and then lift and/or place it over/on the overpass.
I will laugh at the match where there are 6 launcher/racer bots on the field and no one has a way to knock a ball off. It will be tragic, but you know it'll happen and it'll be ironic when it does.
GitHub
  #89   Spotlight this post!
Unread 28-01-2008, 11:03
MrForbes's Avatar
AKA: Jim
We're planning on using our ball knocker-offer (which was our first design concept) to hold the ball down on our catapult before launching.....yup, you definitely need a way to get the ball down if you're planning on shooting it!
  #90   Spotlight this post!
Unread 28-01-2008, 11:13
JonathanLKS JonathanLKS is offline
Code::Blocks
FRC #0610 (The Coyotes)
JonathanLKS will become famous soon enough
Send a message via MSN to JonathanLKS
We're also planning on shooting the ball. I'd post a video but they are all trapped inside our cell phones right now.
Team 610 [ Co-Leader | Head Programmer | Webmaster ]
We're attending: Greater Toronto Regional, San Diego Regional, Championship
Are you allowed to herd another Teams Ball kE7JLM Rules/Strategy 8 06-01-2008 01:17
CVT, which teams are planning on using them for next year? Jeff K. Technical Discussion 51 28-08-2005 00:08
Are there any teams staying in the Marriott for Alanta? Atasuke768 Chit-Chat 6 15-04-2005 23:59
Are your teams offering any help at the UTC & NJ regional cyberknights195 Regional Competitions 4 01-03-2004 10:03
Ball Shooting Rookie000 General Forum 4 12-01-2004 10:33
