Go to Post "If you abuse the easy button, you become it." / "What does that mean?" / "We hit you and you say 'That was easy'" - ScoutingNerd175 [more]
Unread 27-01-2008, 00:57
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: 2008 Omni Drive Code Help
Chicklet can give weird outputs if the calibration is off or if the battery goes low.
I had that problem once and have made sure the battery we use is fully charged whenever we use it.
Try using one of the joysticks as a test to see if the problem occurred in the code or just when the Chicklet and Xbox controller is being used. Since you are having the problem occur with default code and the Chicklet/Xbox, that's almost certainly the problem. Default is pretty solid. If the numbers are inverting in default code with that 250 to 4 flip, it's probably happening because the system is getting that information in to begin with.
Good luck
Steve
Need help in Kevin's 2008 default code robotrobot2 Programming 5 20-01-2008 14:36
Lego Omni Drive Synergy1848 Robot Showcase 19 03-01-2007 11:51
pic: vex omni drive 1902_Battery_SGT FIRST Tech Challenge 6 28-05-2006 17:55
omni drive vs tank |20807 61|2|_ Technical Discussion 49 17-01-2006 13:54
Omni-drive autonomous questions Andrew Schuetze Programming 6 17-01-2006 12:15
