Go to Post Breaking a rule just because you think it is meant to be broken is not good advice. - Andy Baker [more]
Unread 27-01-2008, 02:06
Aren_Hill's Avatar
Build Nifty Things
Re: Keyway Broaching
do you have a keyway broach set? a set of shims?
by my experience you just put it in an arbor press use some oil and make sure its straight up and down, not to difficult.
run it through then use the appropriate shim to get the groove depth required.
hope that helps
A guy who likes robots.
Unread 27-01-2008, 08:15
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Sounds like you have the tools, you're just looking for some advice.
I always tell my students to take the first few notches slowly, and always back off the arbor press after 1 or 2 notches. If the broach is slightly offline, it will snap fairly easily. By backing off the arbor, it allows the broach to realign itself vertically, and you can press again. Be sure that your arbor press is aligned properly.
Lubrication is your friend.
And, we've found that we need to do a third pass with the broach, but from the back side of the part. For some reason the 2nd pass hasn't been cutting deep enough for us, so we've had to flip the part and finish the keyway from the backside. Odd, but it's a new broach set for us this year...
Best of luck,
Bengineer
Unread 27-01-2008, 09:58
Gdeaver Gdeaver is offline
FRC #1640
I assume your cuting the keyways for the Andy mark trans. You may have to do a little filing to get the key in the output shaft keyway.
pic: Homemade Keyway Broaches Gabe Extra Discussion 8 25-05-2007 22:20
Broaching? Easy way? brennerator Technical Discussion 3 22-01-2007 23:32
Standard keyway broach in a metric bushing sanddrag Technical Discussion 2 18-02-2006 01:17
Need help designing keyway in gear sanddrag Technical Discussion 17 31-01-2005 08:43
Non-Standard Broaching sanddrag Technical Discussion 3 17-03-2004 11:46
