Go to Post Just a word of advise dont come running up to someone and say OMG OMG its just remember to introduce yourself first. - Mike Schroeder [more]
Unread 27-01-2008, 03:07
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Re: The oddest error
The reason for saying the battery was because the motors might be pulling different numbers of amps with the different code. Some code may be putting a much greater strain on the motors since it is holding an arm in a particular position and this is much more likely to be the encoder code and not the original code.
However, since apparently the battery is fine, I can't see a reason for this problem. We have had very similar things happen to us in the past but it has always been fixed with a simple battery change. One thing you might check is the resistance of the battery with your multimeter cause if the battery has a bad cell then when the battery has no load it looks fully charged but when put in the bot will drop very low very quick.
If that isn't it then search me, I haven't done a huge amount of programing and certainly don't know the controller as well as I could.
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
Php error on the portal Adam Y. CD Forum Support 1 06-07-2004 11:32
