Go to Post That's some sexy use of aluminium - Bharat Nain [more]
Unread 27-01-2008, 05:07
AdamHeard's Avatar
Lead Mentor
Re: How low do you go?
Originally Posted by sdcantrell56 View Post
I see you're using acetal sprockets. How well do those hold up to competition?
I've seen a few teams solely use them in their drivetrain; Out of the few I talked with, only one team had issues. I believe they had Acetal sprockets without metal hubs and cut keyways into that; those keyways eventually failed. The other teams used the metal hubbed ones or attached them with bolts/pins to the wheels in a dead axle application.
How do you feel about how the Autodesk award winners were decided? R Stephenson Inventor 43 02-06-2007 20:45
Set Default Digital inputs to Low? How? bad Analog value? Generalx5 Programming 11 04-01-2007 18:57
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
How to measure low velocity nobtiba Electrical 28 22-04-2005 05:37
You think we should try doing a grassroots (ie:low tech) version of Ventures? Koko Ed Games/Trivia 1 19-02-2005 09:29
