Go to Post Programmer's pride. FIRST needs some more. - Ben Margolis [more]
Unread 27-01-2008, 09:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Anyone have any leads on the steering wheel controller that uses a 15 pin connect
Originally Posted by eugenebrooks View Post
It is important that you do not connect the ground on the 100K
pots wired to the OI. Follow IFI's instructions for the wiring.
If you actually get the wiper connected to the ground the OI
will send 127 and not 0 to the RC. This "feature" is a safety
measure to keep robots from running wild when a connection
is lost. If you can actually turn the pot far enough to get it
connected to ground the robot will suddenly stop instead of
doing what was intended.
Thanks for the explanation!
We'll work on getting the right resistance pots on the controller for the new robot, and only connect them to power.
what is the four pin white connector for on the ir board ? Smaug Electrical 2 10-01-2008 23:37
ANY TEAM THAT IS GOING TO NATIONALS! Do any of you have..... cdennisxlx2 Kit & Additional Hardware 9 03-04-2007 20:10
Anyone have any pics of the field only (no robots) from previous games? Elgin Clock General Forum 7 07-09-2004 22:13
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
Does ANYONE have a '2001 Competition 10th Anniv.' Pin? archiver 2001 4 24-06-2002 03:38
