Go to Post "Yes, I'd like to Super Size my speed controller combo and add a jumbo distribution block, please." "You want fries with that?" - Travis Hoffman [more]
  #91   Spotlight this post!
Unread 21-01-2008, 00:46
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Re: FIRST Injuries
Although I've never had any MAJOR injuries I hold last year's records for most small cuts in a small period of time...ironic because I became safety captain. In 2 weeks I filed my knuckle, drilled the side of my finger, closed the toolbox on my hand, hit my knuckle on the crank on the mill, took a rotor broach out of a drill press and hit it on my hand, pinched my palm in a joint, and cut myself on the sheet metal on the ramp...rough season :-P
As far as serious injuries someone let the rotor broach walk while lightening and got the nail on their thumb and the skin under it...that was icky, she's fine now though, nothing permanent just looked nasty and painful (which I'm sure it was)
  #92   Spotlight this post!
Unread 21-01-2008, 00:53
Zyik Zyik is offline
Observer
Zyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond repute
Re: FIRST Injuries
At Cal Games we had a team mate jump down some stairs... we thought he just sprained his knee but it turns out he tore his ACL. He's had surgery a couple of times sience then and currently is wearing a brace.
Team 973 : 06-09
  #93   Spotlight this post!
Unread 21-01-2008, 02:32
CzarValvador's Avatar
CzarValvador CzarValvador is offline
AKA: Val
FRC #1717 (D'penguineers)
Team Role: Electrical
CzarValvador has a spectacular aura aboutCzarValvador has a spectacular aura about
Re: FIRST Injuries
Originally Posted by vivek16 View Post
don't mean to be rude but... does it affect your typing much?
That really does suck. How was the whole hospital thing?
thanks, vivek
Hospital thing sucked for a few reasons.
1. They took 4 hours to clean out the Wound and Bandage it up. About 15 minutes of those 4 hours were they actually doing anything.
2. It was my friend's 18th Birthday when it happened, I felt like I was ruining the entire thing since they followed me to the Hospital even though I told them to go home.
And no, it doesn't affect my typing that much anymore. I have now got used to typing without my Ring Finger and Pinky on my right hand (with only occasional miss types). The Ring Finger is the side effect of when it used to hurt when I moved it. The bandage is still on it since the skin hasn't cover the wound yet... not even half.
To my surprise it didn't even hurt that bad when it happened.
Edit: Wait, did you mean my typing was inadequate in any way?
Edit 2: Forgot to mention that last Year's robot attacked Ryan, our electrical mentor, on Saturday when Programming team forgot that for some reason everything resets to zero after a clock cycle (or some other Programmer Mumbo Jumbo) so our robot's arm grabbed the mentors arm and dragged him to the ground.
  #94   Spotlight this post!
Unread 21-01-2008, 08:10
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
Re: FIRST Injuries
Originally Posted by heywuhjab View Post
Mental Note: don't give ZakuAce a butter knife
haha then how will I butter my toast?!
  #95   Spotlight this post!
Unread 21-01-2008, 08:56
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: FIRST Injuries
No, I was just wondering if you missed keys ever or it takes you longer or something.
I haven't gotten seriously injured but there are always those minor cuts and pinches you get. [nonfirstrelated] I burn myself with hot glue waay too much... I guess I should be glad Im not using soldering stuff at all [/nonfirstrelated]
thanks, Vivek
"we don't build robots, we build people"
  #96   Spotlight this post!
Unread 21-01-2008, 12:48
AKA: Val
Re: FIRST Injuries
At first typing was a little harder, but I got used to shifting my hand a little bit to compensate for the two inactive fingers. Although I do slip up a little bit every now and than.
Its kind of like going from Medium to Hard on Guitar Hero... that one extra button makes you shift your hand... hah.
  #97   Spotlight this post!
Unread 21-01-2008, 16:09
heywuhjab's Avatar
heywuhjab heywuhjab is offline
AKA: Hugh
no team (None(and Proud))
heywuhjab can only hope to improve
Thumbs up Re: FIRST Injuries
with a spoon of coarse!
  #98   Spotlight this post!
Unread 21-01-2008, 18:11
vivek16's Avatar
AKA: vivek
Re: FIRST Injuries
with a cleaver...
-vivek
  #99   Spotlight this post!
Unread 21-01-2008, 18:24
!aaaaa! !aaaaa! is offline
Junior Member
no team (the greatest team ever)
Team Role: Mascot
!aaaaa! can only hope to improve
Re: FIRST Injuries
i cut my head off once or 9 times or so
  #100   Spotlight this post!
Unread 22-01-2008, 09:25
joesmomh00haha's Avatar
joesmomh00haha joesmomh00haha is offline
sneeble
AKA: sneeble
FRC #1841 (Crazy Bred)
Team Role: Mascot
joesmomh00haha is infamous around these parts
As we all know, modern media thrives on sensationalism. The purpose of the thread was to raise awareness to all of the injuries that occur in FIRST. As you can see in the span of 5 days there have been 98 posts and 2500 views, job well done by us getting the word out. WE APOLOGIZE if a few feathers were ruffled or if anyone got offended, but can't you see that awareness of safety has been generated?
So if you have stories post them but if have an injury and you happen to get a picture....we still want to see it, we're not looking for terribly graphic wounds but a few scrapes and cuts here and there are fine.
  #101   Spotlight this post!
Unread 26-01-2008, 14:11
catatac2225's Avatar
catatac2225 catatac2225 is offline
Pneumatics!
AKA: Tanya
FRC #2225 (Catatac)
catatac2225 is an unknown quantity at this point
Re: FIRST Injuries
One of the members on our team got savagely attacked by a zip tie. He still has the scar.
  #102   Spotlight this post!
Unread 27-01-2008, 11:59
joshsmithers's Avatar
joshsmithers joshsmithers is offline
go team 4910! get that FLL!
AKA: username-ers=myname
FRC #0587 (Hedgehogs)
joshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of light
Re: FIRST Injuries
The funniest i've seen was last year at Palmetto Regional. We shared one side of our pit with 1618, so I was watching them fix their robot. They turn it on to test it and Billfred is lucky enough to be standing in front of their CIM driven arm. Not even my good ol physics teacher from the appalachains could produce a louder "yelp".
Genius is 1 percent inspiration and 99% perspiration, which is why engineers sometimes smell really bad.
  #103   Spotlight this post!
Unread 27-01-2008, 12:17
Romeo1351's Avatar
Romeo1351 Romeo1351 is offline
Your Friendly Neighborhood Geek
AKA: Nicholas Corgan
FRC #1351 (Mitty Robotics)
Team Role: Webmaster
Romeo1351 is an unknown quantity at this point
Send a message via AIM to Romeo1351 Send a message via Yahoo to Romeo1351
Re: FIRST Injuries
I learned not to reach across the table while someone else is holding a soldering iron. Burned between my fingers.
And heh, a story about another team member, our 2007 Head of Software/Electronics was soldering, and a mechie was next to her.
Mechie: "Wow, I could never solder that stuff together so fast..."
Head: "Well, that's why I'm Head of---OUCH!"
Excellent timing.
Oh, and now that I remember...our school, back in 07, used sports as a theme for their Back-to-School Dance. So obviously, 5-6 of us went in our TKO blue, resistor earrings, etc. I decided, idiotically enough, on a "zip tie ring". Had to bite the darn thing off when I realized my finger was a few shades too dark.
"We're nonessential engineers! If this were Star Trek, we'd be dead!"
---1351's Katie, SVR '06
Currently: Website Head, Programmer
  #104   Spotlight this post!
Unread 16-02-2008, 12:16
J-me J-me is offline
FRC #1566
J-me is an unknown quantity at this point
Re: FIRST Injuries
Hey! I thought i was the only one with stupid injuries!! last year i was holding some metal things together for another person to drill...and well...the drill skipped a bit and hit the right side of my right hand...i lost most of the feeling on the right side for a month or two...i learned my lesson for helping guys out without wearing gloves!!
  #105   Spotlight this post!
Unread 16-02-2008, 21:22
Jakob Jakob is offline
FRC #0128
Jakob is on a distinguished road
Re: FIRST Injuries
So many people on our team have been hit with these STUPID arms that we have....In the knee, in the arm, and in the head. I mean, seriously!
were there robot related injuries on your team? Will Hanashiro General Forum 233 08-03-2009 15:42
This Weekend! - Delaware FIRST Vex Challenge & First State FIRST LEGO League Tourney Mr MOE General Forum 4 28-01-2007 07:59
**FIRST EMAIL**/FIRST Annual Fund Message from James R. Utaski, FIRST Board of Direct miketwalker FIRST E-Mail Blast Archive 0 27-05-2004 11:25
Injuries pauluffel General Forum 69 26-02-2003 23:01
First Injuries Wolfe General Forum 34 15-05-2002 22:14
