Go to Post I just... I can't even comprehend it. Like, my brain is soup. Commas are everywhere. Sentences. Shrinking. zzzzzzzzzzzz... - PayneTrain [more]
Unread 27-01-2008, 12:37
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
Wiring the IR Receiver
I know this has been discussed before, but I am curious about the voltage requirements of the IR Receiver. The documentation states that it requires between 7 and 15 volts of power. For the sake of reducing wiring and the use of expensive PWM cables, I proposed that the entire board be powered off of two pwm cables. Basically we would have one cable sitting sideways across Digital Inputs 14 - 16. It would cover all of the signal pins on these Digital Inputs. The second cable would be on Digital Input 17. This would have the ground, +5V, and Signal. The ground would be connected to the ground, the +5V would be connected to the power. The 4 other wires would each be connected to a signal pin.
I have tested the IR sensor with my bench top power supply and it was able to operate all the way down to 3.5 Volts.
Does anyone see any problems with setting the sensor up like this? The electrical advisor wants to pull power off a of a PWM, but I am trying to reduce the wiring and keep everything organized.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
Making the IR receiver Omni Directional Spylake Technical Discussion 0 08-01-2008 13:00
Using the IR Receiver on the Robot LG67 Control System 1 06-01-2008 01:42
GPS receiver John Gutmann Technical Discussion 23 01-03-2007 02:35
IR Receiver zachriggle Electrical 7 09-02-2006 17:11
How to connect the R/C receiver?! Tim Skloss Robotics Education and Curriculum 7 10-12-2003 16:34
