Go to Post I wake up at noon on Christmas Eve, and find tweets announcing a game hint. Looks like I won't be seeing much of my family today... - Karibou [more]
  #46   Spotlight this post!
Unread 27-01-2008, 13:28
Re: Robocoach signals loophole?
Originally Posted by galewind View Post
Would this be legal?
You have an IR command that signals the robot to execute command Y after it is finished executing command X, where X could be a routine from another signal or an automated routine.
If the robot is not executing X, it will execute Y immediately, and if it is executing X, it will execute Y when it is finished with X.
Yes. I believe that very situation has been addressed by Q&A.
  #47   Spotlight this post!
Unread 27-01-2008, 13:43
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Originally Posted by RyanW View Post
the CMUCAM module given out in previous years is a custom part made specifically for those FIRST competitions. It may not be used.
The first sentence is true, but the second one is false. The CMUCam that came in the 2007 KoP is still available from IFI, so it is considered a COTS part, and is legal under <R35>. The 2006 CMUCam is not available COTS, and is specifically prohibited by <R36>, so it is not allowed.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
  #48   Spotlight this post!
Unread 28-01-2008, 20:30
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
A couple of interesting Robocoach-related Q&A responses came out today:
http://forums.usfirst.org/showthread.php?t=8460
http://forums.usfirst.org/showthread.php?t=8455
_
  #49   Spotlight this post!
Unread 28-01-2008, 23:45
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I thought of an interesting "loophole" in the rules...
A remote like the Logitech Harmony series allows you to program some of the buttons on the computer. Now, the GDC wants you to have 1 button push correspond to one action, with a max of 4, and they don't want you to encode longer messages by pushing multiple buttons, which rules out the idea someone had of using encoded messages to help stave off interference from other teams.
But what if you programmed a remote to send multiple number messages for each push? You only use 4 buttons, and those 4 buttons only activate 4 activities on the robot. each single button press leads to one action on the robot. But you're sending a string of signals with each press to avoid interference with other robocoaches.
From update 3, this may be allowed (i think we'll draft a question to the GDC about it, so i'm not really looking for approval here, just opinions):
The RoboCoach may use up to four different buttons on the TV remote to transmit
up to four different messages to the Robot. To transmit “message #1” she would
press Button #1, to transmit “message #2” she would press Button #2, etc. Only
four buttons are available for use in this manner. All other buttons or combination of
buttons should be ignored by the Robot. Pressing multiple buttons simultaneously,
or in a sequence, also should not result in a valid message recognized by the
Robot.
So one button push transmits one message, and multiple button pushes don't encode other messages... I don't know, what do you guys think? Am i going out on a limb here?
  #50   Spotlight this post!
Unread 28-01-2008, 23:57
You're on a limb, but it's a relatively thick one. Get that question asked to confirm. (And the post here is a pretty good base for it.)
If I had to make a ruling, here and now, with the information available, I would say legal. I am, however, not on the GDC.
  #51   Spotlight this post!
Unread 29-01-2008, 01:54
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
If you are using a standard commercial IR remote control, you are already doing this.
When you mash the "3" button on an IR remote, the device does not just send "3" out over the IR LED. That information is actually buried inside a larger packet of information that is sent each time a button is pushed. The packet will typically contain (as a minimum) synch pulses, the target device address, an encoded version of the data, and termination pulses.
Depending on the device being used, the actual "data" content can be a small fraction of the total transmitted packet. For example, if the remote uses the Control-S protocol (used by Sony - the two most common protocols are from Sony and NEC), you get a header pulse, a seven-bit data block, a five- eight- or thirteen-bit target block, and a trailing pulse. Of the data block, only 10 of the 256 seven-bit permutations correspond to the numbers on the remote. All the rest of the packet space is used by the remote to encode other information that is used by the receiver to decode and direct the data.
So what is being proposed as an advantageous "loophole" is, in fact, already in place and the rules support and accommodate it.
-dave
  #52   Spotlight this post!
Unread 29-01-2008, 09:16
Mentor, LRI, MN RPC
-dave
Yeah, i understand how a remote typically works - the only real difference between programming a remote to send multiple signals every button press and that is the possibility for interference. There are only so many manufacturers, and each of them only has a few different types of signals they use (if you look at the instructions for a programmable remote, they usually have a lookup table by brand with at most 50 or so values). By using a standard remote with a standard (single) signal for each button, you risk that someone else is using the same type of remote, or is programmed for the same brand and you risk their commands telling your robot what to do. With the sizes of the regionals, odds are this'll happen to someone at each regional... by encoding longer messages, you significantly reduce or even eliminate this risk, and that is really the part that isn't already contained within the general understanding of the rule.
Robotics Hand Signals JulieB Chit-Chat 21 19-06-2005 00:11
PWM Signals stevex Programming 1 28-10-2004 18:03
IR signals inverted Atheist Electrical 10 08-02-2004 16:27
Autonomous user-input loophole? Jeff McCune Programming 20 14-02-2003 22:44
Referee hand signals archiver 1999 1 23-06-2002 21:57
