Go to Post These awards aren't easy to get, and if a team deserves an award, they deserve to be cheered on for it. - tckma [more]
Unread 27-01-2008, 12:26
Chaos204's Avatar
Chaos204 Chaos204 is offline
AKA: Jordan
FRC #0204 (Eastern Robotic Vikings)
Chaos204 is on a distinguished road
Send a message via AIM to Chaos204
Banebot Planetary Mounting
This year we are planing on using the Banebot planetary gearboxes for our drive system, and i am curious about the best mounting strategy.
2005 PARC FINALIST
with 84 and 176
E. R. V. is on its way
Unread 27-01-2008, 12:43
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Banebot Planetary Mounting
That depends!
If you give us a lot more information, such as what you are using for the frame, what drive setup you will have (2wd, 4wd, 6wd, etc), what type wheels you're using, and stuff like that, we could probably give some recommendations.
Unread 27-01-2008, 13:07
Chaos204's Avatar
AKA: Jordan
we will be going front wheel drive with ball casters on the back. we are going to use our modified lawn mower wheels for the drive wheels i attached a screen shot of a model of the frame (as it is now) I did in Google sketchup it is all welded, the top level is 1 inch angle the bottom is 2 inch angle the corners are 5 inches vertical.
2005 PARC FINALIST
with 84 and 176
Unread 27-01-2008, 13:20
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Do you already have your frame made? It looks like it could be a little flimsy and I would recommend adding a couple of crossbars in the middle. Then simply mount your gearboxes onto the crossbars and drill a hole out of the side of them (assuming you would use angle for the crossbars) for the shaft to come out of. I would NOT direct drive the wheel on the gearbox. Run chain instead.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 27-01-2008, 13:46
Chaos204's Avatar
AKA: Jordan
The frame, as it is now, is quite stable, but there will defiantly be cross bars bolted in once the individual systems are finished. For instance I was thinking i would mount a aluminum plate to parallel cross bars then mount the gear box to it, but this would leave the rear unsupported. I haven't received the boxes yet i am only going off of last year's bane bots and pictures online.
Do you say not to direct drive because of the nature of the planetary gearbox? Because we have done very well in the past with it direct drive to a normal style gearbox.
2005 PARC FINALIST
with 84 and 176
256:1 planetary Rosiebotboss General Forum 1 21-01-2008 12:29
Custom Planetary Aren_Hill Technical Discussion 2 16-11-2007 20:43
Andymark Planetary Alex.Norton Technical Discussion 3 06-07-2007 11:12
Planetary trouble Torboticsmember Motors 3 09-02-2007 00:26
pic: Planetary...Wheel? Matt Krass Extra Discussion 23 27-06-2005 16:05
