Is there anything in the rule book that I might have overread that says you cannot lay a battery on its side? Id appreciate some answers
Re: Battery Question?
It should be ok. Our teams rookie year we put the battery in sideways. It could have changed since then though.
Joey |
Nothing against it this year--or in recent memory.
It's fine
Thanks for the help!
the sealed lead acid batteries used in FIRST can be used in any orientation and are generally a very forgiving battery in terms of how much abuse it can take before it is no longer useful. almost all the conditions it goes through in a FIRST regional are far outside of what the battery is intended to be used for, such as draining it to 9 volts in 4 minutes. only thing I really have against these batteries is the rules about not being able to use other brands of batteries and this business about using only 6amp automotive chargers in the rules, which I don't recall being in previous years.
#7
This has been in the rules all the way back to at least 2002. It is really unsafe charging these batteries faster then 6 amps.
#8
afterthought: it isn't safe charging them faster than 6 amps, yet its safe to discharge them at 80amps? I'm not attacking your post or you in any way, I'm just generally unhappy about the battery rules and for some reason extra unhappy right now. Last edited by eeeeweeezeee : 22-01-2008 at 01:37. |
#9
In the past the rule...
<R48> The ES17-12 shall only be charged between MATCHES by a 6-ampere rated automatic battery charger. When recharging the Kit Of Parts batteries, either the charger provided by FIRST or an automatic charger with an equivalent charging current rating may be used. has been interpreted as to allow the lesser current. First provided 4 amp chargers many years ago when we first started using the 12 volt gel cell batteries. If you are concerned, please ask the Q&A. Yes we are stressing the batteries at the load we place on them, but it is for only two minutes. A high current charger left on for several hours is likely to produce excessive heat in the battery which can produce some nasty venting of gas and damage to the internal assembly. Yes, I have seen teams bring in fifty amp chargers and hook them up with aligator clips in the pit. I hate the smell of sulpheric acid and burning plastic in the morning. |
#10
Lead acid batteries when charged can generate quite a bit of heat when charged at a fast rate, and actually charging a 17Ah battery at 6 amps is rather fast (C/3), where it is deep cylce you won't run into the problems like you would with an automotive battery if you "cook" it with a very fast charge, with the automotive batteries you can actually "sluff" of plates of the battery and possibly cause it to vent, especially with the increased temperature and also with the gases that are generated during charging, which in a side note is also flamable... Those are just some of the reasons that you dont want to charge especially a sealed lead acid battery at more than C/3 Tim Batteries Plus New Hampshire Loooking for extra batteries, check out my white paper ! |
#11
i read that the battery terminals have to be at least 4 inches form the ground
#12
No rules about that...Or can you quote one?
#13
There are advantages and disadvantages of putting your battery upright or laying down. You must determine which one suits your robot the best.
#14
That's a new one. I have never seen a battery rule about height above ground. However, if the battery falls out of your robot and is being dragged around, you will be disabled.
#15
"<R15> The judges, referees, and announcers must be able to easily identify ROBOTS by team number. Teams shall display their team number in four locations at approximately 90- degree intervals around the perimeter of the ROBOT. The numerals must be at least 4 inches high, at least in 3/4 inch stroke width and in a contrasting color from its background. Team Numbers must be clearly visible from a distance of not less than 100 feet." "<R18> ROBOTS must use the LAP INDICATOR provided by the field personnel during all official tournament MATCHES. The LAP INDICATOR is attached to the stopper on the flag pole. When the FLAG is placed in the flag holder, the stopper will insert into the top of the holder. To accommodate the LAP INDICATOR, the area within a minimum 180—degree horizontal arc around the top of the flag holder must be kept clear of any obstructions within a 2-inch radius. This region must be kept uncovered and visible from above. To ensure that every FINISH LINE CROSSING is properly recorded, the LAP INDICATOR must be visible to the Lap Detectors when the ROBOT passes under the OVERPASS. The LAP INDICATOR is powered via a standard three-wire PWM cable. An easily accessible, powered, male PWM connector must be located within 4 inches of the LAP INDICATOR mounting location. The port may be either a direct connection to an analog or digital port on the Robot Controller, or a remote “pigtail” connection to the Robot Controller port." |
| Back-up Battery question | Oumonkey | Kit & Additional Hardware | 21 | 21-02-2007 12:45 |
| battery question | hiimcristhian | General Forum | 6 | 09-02-2007 11:38 |
| Battery question | CraigHickman | Electrical | 9 | 23-10-2006 21:55 |
| Extra Battery Question | 1337pcgamer | General Forum | 1 | 16-02-2006 19:58 |
| Help!!! Battery question | trollin1st | General Forum | 7 | 12-02-2003 08:48 |
