Go to Post ...the list of the things we want to get done in the off-season has grown to such a length that I have to take off my shoes and socks to count them...and I think I may need to grow a few more toes soon. - StephLee [more]
Unread 27-01-2008, 01:07
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Re: Anyone have any leads on the steering wheel controller that uses a 15 pin connect
A tad bit late, but I'll post this ..
1388 has been using Saitek R100 wheels for the last 3 (going on 4) years now. I find them on ebay for between $0.01 and $15 .. they seem to work great, and have buttons on the wheel for shifting. There are USB versions, so confirm it's the 15 pin version before buying. They work fine without the pedals attached.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 27-01-2008, 01:45
AKA: Dr. Brooks
no team (WRRF)
It is important that you do not connect the ground on the 100K
pots wired to the OI. Follow IFI's instructions for the wiring.
If you actually get the wiper connected to the ground the OI
will send 127 and not 0 to the RC. This "feature" is a safety
measure to keep robots from running wild when a connection
is lost. If you can actually turn the pot far enough to get it
connected to ground the robot will suddenly stop instead of
doing what was intended.
This safety measure does not exist for pots connected to the RC
and you connect the ground on these.
Eugene
Originally Posted by squirrel View Post
If you look at the wiring diagram for the joysticks suggested in the IFI documentation, you'll see that they show that the 100k pots are only connected to signal and +5V, and not to ground. Last year we connected all the pots on to the OI using 3 wires each: ground, signal, and +5v, and everything worked fine. This makes the pot into a voltage divider, and the signal voltage is proportional to how far the pot is moved towards the +5V end.
You might want to ask IFI is this is an acceptable way to wire up a pot to the OI before you try it.
We wired up that Futaba controller to the 2007 robot OI this way and it works fine.
Unread 27-01-2008, 08:29
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
http://www.chiefdelphi.com/media/photos/29882
I have no clue what was done internally to make it work. But, to answer your question, our programing team has it figured out. Before they put it back together I remember seeing lots of soldered connections and electrical tape.
Unread 27-01-2008, 09:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Thanks for the explanation!
We'll work on getting the right resistance pots on the controller for the new robot, and only connect them to power.
Unread 27-01-2008, 17:23
AKA: Dr. Brooks
no team (WRRF)
If you are stuck with a pot that is not 100k, the OI circutry is tuned for that value, you can measure the voltage for the trip point and then work out the value of an additional resistor to connect between the pot and ground to keep the voltage above, say, twice the trip point. This will allow you to successfully use a pot that is not 100K. We employ this trick when we need to use a 10 turn pot on the OI. We have never been able to find a 100K ten turn pot.
Unread 30-01-2008, 12:58
WaterFreak WaterFreak is offline
FRC #0708 (Hardwired Fusion)
WaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to behold
Currently, Team 708 plans to use somewhat cludgey, but think it should work.
We have a steering wheel that went to a PS2/GameCube/Xbox (not 360).
We bought an adapter from here: sewelldirect.com to convert it to USB.
We have the USB chicklets from IFI to convert it over to 15 pin.
Will do all the programming necessary to make it work hopefully.
Have no clue if this is actually going to work, but time will tell.
Thanks, Jim Orr
Senior Software Engineer - Motorola, Connected Home
Supporting Team 708 - Hardwired Fusion
what is the four pin white connector for on the ir board ? Smaug Electrical 2 10-01-2008 23:37
ANY TEAM THAT IS GOING TO NATIONALS! Do any of you have..... cdennisxlx2 Kit & Additional Hardware 9 03-04-2007 20:10
Anyone have any pics of the field only (no robots) from previous games? Elgin Clock General Forum 7 07-09-2004 22:13
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
Does ANYONE have a '2001 Competition 10th Anniv.' Pin? archiver 2001 4 24-06-2002 03:38
