Go to Post To quote Harrison Ford: "Never tell me the odds". - [more]
Unread 27-01-2008, 17:32
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Team 1711 prototype
Originally Posted by 7-11number1 View Post
we stretch out to 81 inches when the arm lifts up and is in possession of a ball. Luckily its the third week so we can adjust for that
Remember it's not 80" long it's fitting into a 80" circle.
BTW I love the design.
Unread 27-01-2008, 17:37
Jaybee1405
Posts: n/a
No it's not. You may not have any two points more than 80" apart (horizontally).
Unread 27-01-2008, 17:42
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That's neat! uses up a lot of air though, doesn't it? we are also dealing with air consumption issues
Unread 27-01-2008, 17:43
IndySam's Avatar
<R16> Once the MATCH has started, the ROBOT may assume a PLAYING CONFIGURATION that exceeds the size dimensions specified in Rule <R11>. While in the PLAYING CONFIGURATION, the ROBOT may expand up to a maximum horizontal dimension of 80 inches (e.g. all parts of the ROBOT must fit within an imaginary 80-inch-diameter upright cylinder).
Read this http://www.chiefdelphi.com/forums/sh...&highlight=r16
Unread 27-01-2008, 17:45
MrForbes's Avatar
AKA: Jim
We've been thru the 80" rule discussion in a few different threads...and the Q&A addresses it also....the circle thing is an example, but the rule says only that you can't have two points further apart than 80" in a horizontal direction.
Measuring this can be a bit difficult.
Unread 27-01-2008, 17:48
Jaybee1405
Posts: n/a
I was told by an official FIRST regional inspector that it is not an upright cylinder. The shape is more like a very high piece of pie (ex. take an 80" long piece of extrusion and make a sweep from the farthest point.
Thank you Squirrel.
Team 100's prototype spinmunky Robot Showcase 10 15-01-2007 12:56
Team 358 Shooter Prototype Xero0ne Robot Showcase 14 20-01-2006 21:03
pic: Team 1595 Prototype!!! L@@K sgsdragons Robot Showcase 18 10-02-2005 14:27
