Go to Post Life can be painfully short and you never know how things could change in an instant. It never hurts to say thank you. - Karthik [more]
Unread 27-01-2008, 18:29
Re: Wiring the IR Receiver
Originally Posted by Rapt0r9 View Post
Also, I've noticed that there is a 5 Volt Regulator on the board, so this leads me to further believe that 5 Volts is an acceptable supply voltage for the sensor.
A 78XX regulator reuires a minimum of 2 volts across the device for operation. If you feed the regulator with 5 volts, the output will be 2 volts below that which is not enough for the devices to reliably operate and my be so low as to trigger the power function of the controller. The 7 volt minimum satisfies the 5 volt regulator and it is designed to work up to a fifteen volt input. So the specs have more to do with the 7805 then with the operation of the board itself. Although you could run it off a PWM the power there is coming from the 7.2 volts backup battery. I would go as recommended, attach to a breaker and the main power, +12.
Making the IR receiver Omni Directional Spylake Technical Discussion 0 08-01-2008 13:00
Using the IR Receiver on the Robot LG67 Control System 1 06-01-2008 01:42
GPS receiver John Gutmann Technical Discussion 23 01-03-2007 02:35
IR Receiver zachriggle Electrical 7 09-02-2006 17:11
How to connect the R/C receiver?! Tim Skloss Robotics Education and Curriculum 7 10-12-2003 16:34
