Go to Post Gotta love the use of universal technical terms, along with whatchamacallit, doodlespiel, whosiwhatsit... ;) - PaW [more]
Unread 27-01-2008, 12:37
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
Wiring the IR Receiver
I know this has been discussed before, but I am curious about the voltage requirements of the IR Receiver. The documentation states that it requires between 7 and 15 volts of power. For the sake of reducing wiring and the use of expensive PWM cables, I proposed that the entire board be powered off of two pwm cables. Basically we would have one cable sitting sideways across Digital Inputs 14 - 16. It would cover all of the signal pins on these Digital Inputs. The second cable would be on Digital Input 17. This would have the ground, +5V, and Signal. The ground would be connected to the ground, the +5V would be connected to the power. The 4 other wires would each be connected to a signal pin.
I have tested the IR sensor with my bench top power supply and it was able to operate all the way down to 3.5 Volts.
Does anyone see any problems with setting the sensor up like this? The electrical advisor wants to pull power off a of a PWM, but I am trying to reduce the wiring and keep everything organized.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
Unread 27-01-2008, 12:40
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Wiring the IR Receiver
Just run the power and ground to the small fuse block and you are good to go.
That is all you have to do to power it.
Ed Barker
Unread 27-01-2008, 12:48
Rapt0r9's Avatar
AKA: Tyler
I see that we could power it via a fuse block, however, I am trying to do everything through the two PWM cables to help avoid the rat's nest of wire that we commonly have around the RC.
I am just questioning if anyone sees an issue supplying the sensor 5 Volts instead of the 7 - 15 which is recommended. Also, I've noticed that there is a 5 Volt Regulator on the board, so this leads me to further believe that 5 Volts is an acceptable supply voltage for the sensor.
Unread 27-01-2008, 14:41
ham90mack's Avatar
ham90mack ham90mack is offline
President of RIT FIRST
FRC #0073 (The Illumination)
ham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really nice
We just got our IR receiver working yesterday, although it didn't work for signaling the controller at first since we used a separate 9v battery and the controller thought that it was always receiving a signal (something about a floating ground was the explanation... o_0). But once we connected both power and ground pins from the receiver to the digital input's power and ground, the board worked fine with no power problems. I wouldn't guarantee it to work with only one power and ground pin connected, but it might... Maybe they just said seven volts to guarantee that the board will work, or having two sources of 5v power allows the board to draw enough current to power itself since it has two places to draw from.
Old stuff:
FRC 2007 Strategy Solver. Version: 2.55. Progress: done.
Unread 27-01-2008, 14:58
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Here is what we did...
We hooked it to the 12V BUSS fuse panel and then through another inline fuse holder that is rated at .75 of an AMP. For connecting it to the Digital I/O, we cut off one of the ends of the old LED competition lights (Please don't cut the one from this year). It has 4 wires, and you need 4 wires, so it works perfectly. I think the last ones were shipped in 05' and maybe 06' but I don't remember.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 27-01-2008, 18:29
A 78XX regulator reuires a minimum of 2 volts across the device for operation. If you feed the regulator with 5 volts, the output will be 2 volts below that which is not enough for the devices to reliably operate and my be so low as to trigger the power function of the controller. The 7 volt minimum satisfies the 5 volt regulator and it is designed to work up to a fifteen volt input. So the specs have more to do with the 7805 then with the operation of the board itself. Although you could run it off a PWM the power there is coming from the 7.2 volts backup battery. I would go as recommended, attach to a breaker and the main power, +12.
Unread 27-01-2008, 18:45
RyanN's Avatar
RyanN
I would definitely use 12V. If you use the 7.2V backup battery, you are only giving yourself a leeway of 1/5 of a volt (our backup battery was dead... around 6.5V). I believe under-volting the IR board can cause it to fail, as was in our case. The programming within our PIC controller failed. If you put it on a 12V circuit, you give it a 5V leeway, which is pretty good.
Controls Mentor
@rnazaretian
Previous teams:
Unread 27-01-2008, 22:44
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
We just took the digital in/out and bridged 14 and 15 ground and power to our IR board and it was working with no problems (and this way your nor running off of your backup and your still giving the board 10 volts... also minimizing wire runs)
Unread 28-01-2008, 00:24
RyanN's Avatar
RyanN
How did you "bridge" the connection? Did you tie two +5 together, and the two GNDs together or did you do GND, +5 to GND, +5? Either way should not work, and the second way mentioned will short out the +5V strip. The first way would still only give you +5V. I think you are saying you did it the 1st way.
The first way is a parallel circuit. It will not increase and will not decrease the voltage. In this certain case, it will also not increase the amount of current.
What you should have is a series circuit, which WILL NOT work with the RC. This would have two power sources... You take the negative of ES1, tie the positive from ES1, and tie it in with the negative of ES2, and then take the positive of the ES2 (ES1 = energy source 1, ES2 = energy source 2). You get the voltage by adding the voltage of each energy source. (Say you have 2 7.2V batteries, and you hook them in series, then you would have 14.4V.)
Parallel circuits are completely different. The current changes, and the voltages should be an average of the energy sources (I have a 6V and a 12V battery, and put them in parallel [Bad idea by the way, don't do this] then the voltage should be around 9V.) As for the current, if you have 2 12V 17AH batteries put in parallel, it should make the output current 12V and 34AH.
So, to make this concise...
Parallel = adds more current
Series = adds more voltage
If it is working fine, then do what you wish. All I am saying is that we tried it with the 7.2V backup battery and killed ours. Check your voltage with a multimeter to see if you are actually getting 10V, because I really doubt you are.
Controls Mentor
@rnazaretian
Previous teams:
Unread 28-01-2008, 00:37
popo308's Avatar
AKA: Brent
Ok i will check the voltage tomorrow at the shop but ours was working perfectally fine running off port 14 and 15 of the RC
Unread 28-01-2008, 07:20
Ryan,
Unfortunately this is not the case. The six volt battery voltage would rise slightly during the time the 12 volt battery would be able to supply it current. The 12 volt would continue to try and dump current until it fell to 6 volts as well. If both batteries were fully charged to begin with, all the excess current would be turned into heat likely destroying the batteries or at least causing some nasty venting.
In the case of the 12 volt batteries in parallel, one will always be slightly higher voltage than the other. This condition will cause current flow between each of them as they ping pong trying to deliver current to the lower voltage battery. Without diodes directing current flow, the two batteries, over time will deplete each other right down to zero volts.
Brent,
The way you hooked up the power will work until the backup battery falls below the 7 volt cutout on the regulator. At that point the regulator is no longer functioning and acts more like a resistor. It may work for a while but may not be reliable.
Unread 28-01-2008, 08:10
RyanN's Avatar
RyanN
Ryan,
Brent,
Interesting fact I did not know about 2 of the same voltage batteries depleting each other...
And I was pretty sure that there would be some nasty venting if one were to try to parallel 2 different voltage batteries (hence the reason I said not to try this ).
Also, Brent said that he was using the Digital I/O port to supply power, which is a regulated +5V from the main 12V battery. It does not rely on the backup battery.
Controls Mentor
@rnazaretian
Previous teams:
Unread 28-01-2008, 09:45
Yes, you are right. I shouldn't answer before coffee. The effect would be the same, unreliable operation.
Unread 28-01-2008, 13:37
GRS GRS is offline
FRC #1764
GRS is an unknown quantity at this point
You can try wiring a 0 ohm resistor in parallel with the voltage regulator, there should be two soldering spots next to the regulator on the right that you could use to bypass it with.
Unread 28-01-2008, 14:05
Please note the schematic found here...
http://www.usfirst.org/uploadedFiles...0schematic.pdf
has a note in the upper right hand corner. Use the zero ohm jumper only if you remove the regulator.
Making the IR receiver Omni Directional Spylake Technical Discussion 0 08-01-2008 13:00
Using the IR Receiver on the Robot LG67 Control System 1 06-01-2008 01:42
GPS receiver John Gutmann Technical Discussion 23 01-03-2007 02:35
IR Receiver zachriggle Electrical 7 09-02-2006 17:11
How to connect the R/C receiver?! Tim Skloss Robotics Education and Curriculum 7 10-12-2003 16:34
