Go to Post For those of you who don't want to read a block of text: Respect the Tools. - Andrew Schreiber [more]
Unread 27-01-2008, 18:45
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Wiring the IR Receiver
A 78XX regulator reuires a minimum of 2 volts across the device for operation. If you feed the regulator with 5 volts, the output will be 2 volts below that which is not enough for the devices to reliably operate and my be so low as to trigger the power function of the controller. The 7 volt minimum satisfies the 5 volt regulator and it is designed to work up to a fifteen volt input. So the specs have more to do with the 7805 then with the operation of the board itself. Although you could run it off a PWM the power there is coming from the 7.2 volts backup battery. I would go as recommended, attach to a breaker and the main power, +12.
I would definitely use 12V. If you use the 7.2V backup battery, you are only giving yourself a leeway of 1/5 of a volt (our backup battery was dead... around 6.5V). I believe under-volting the IR board can cause it to fail, as was in our case. The programming within our PIC controller failed. If you put it on a 12V circuit, you give it a 5V leeway, which is pretty good.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Making the IR receiver Omni Directional Spylake Technical Discussion 0 08-01-2008 13:00
Using the IR Receiver on the Robot LG67 Control System 1 06-01-2008 01:42
GPS receiver John Gutmann Technical Discussion 23 01-03-2007 02:35
IR Receiver zachriggle Electrical 7 09-02-2006 17:11
How to connect the R/C receiver?! Tim Skloss Robotics Education and Curriculum 7 10-12-2003 16:34
