Go to Post Robot shoots forward across field and jams itself into opposing alliance bridge. It was, however, the fastest our robot ever went. - PandaHatMan [more]
  #301   Spotlight this post!
Unread 26-01-2008, 19:50
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: New C18 3.0+ Compatible FRC Code
Julan,
Did you define the number of channels in the adc.h file?
Kevin,
The code runs fine if called ifi_frc.hex.....if I change the project in the same subdirectory with all the same files, I get a stuck programming mode light.
So I won't every change the name, but I'd still like to know why this hapens!!
Jon
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
  #302   Spotlight this post!
Unread 26-01-2008, 19:52
1jbinder 1jbinder is offline
FRC #0852
1jbinder is an unknown quantity at this point
Yes I Did
  #303   Spotlight this post!
Unread 26-01-2008, 19:55
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Variables Change randomly
PLEASE I CANNOT TAKE THIS ANYMORE
Any functions I create return seemingly random numbers
for example I put the function
unsigned int Motor_Limit (int motor)
static unsigned int lmnewmotor;
if(motor >= 254)
lmnewmotor = 254;
if(motor <= 0)
lmnewmotor = 0;
In ifi_code.c and a prototype in ifi_code.h. I call it with
motor1 = Motor_Limit((int) motor1);
where motor1 is a pwm value that may be invalid.
IT ALWAYS RETURNS 1919!!!!
WHYYYYYYYYYY
Is this a bug, I have the sensors version and kevin's site said that it was relatively bug free.
We have a demo tomorrow and whenever I try to run my code the robot goes int a spasm.
  #304   Spotlight this post!
Unread 26-01-2008, 20:05
Re: Variables Change randomly
How do you know what the return value is? I once spent hours trying to debug a routine that seemed to be returning the wrong value, only to discover that the error was in the line of code that prints the value.
But upon further inspection, the problem with your code is rather obvious to someone who hasn't been staring at it for hours. You merely forgot to return the newly computed value.
  #305   Spotlight this post!
Unread 26-01-2008, 20:13
AKA: Mark
Exclamation Re: New C18 3.0+ Compatible FRC Code
I cannot adequately express my frustration with myself and the people here who I asked to check this for error. Thank you for pointing out that I DIDNT HAVE IT RETURN ANYTHING AAAAAAAAAAAAA
  #306   Spotlight this post!
Unread 27-01-2008, 00:38
Boku-Ni's Avatar
Boku-Ni Boku-Ni is offline
AKA: Hank
FRC #1289 (Gearheadz)
Boku-Ni is an unknown quantity at this point
Send a message via ICQ to Boku-Ni Send a message via AIM to Boku-Ni Send a message via MSN to Boku-Ni
I looked at the link that was provided for a version of C18 other than 3.15 but couldn't find it. Can someone point to me where it is? >.< Any help appreciated.
-- Hank
Programmers don't byte, they nibble a bit.
"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones." -- Albert Einstein
  #307   Spotlight this post!
Unread 27-01-2008, 10:11
-- Hank
The link in the first post for C18 has both 3.10 and 3.15.
  #308   Spotlight this post!
Unread 27-01-2008, 10:22
Originally Posted by PhilBot View Post
And finally I have
long Get_Gyro_Angle(void)
// Return the calculated gyro angle to the caller.
return(((gyro_angle * GYRO_SENSITIVITY * 5L) / (ADC_RANGE * ADC_UPDATE_RATE)) * GYRO_CAL_FACTOR);
So, since I've been caught before on this one.. I calculated the value of the divisor of this expression. ADC_RANGE * ADC_UPDATE_RATE = 2048 * 100 = 204800. So I'm dividing a "Long" by this number.... I should be able to calculate the maximum result I can get...
Max Long is 2147483648 so if I divide this by 204800 I get 10485 ... Which, in theory is the maximum result I can get...
But wait, this is millirads so the maximum angle I can measue is... just over 1.6 full rotations...
Oops... Either I did my math wrong, or I have to reduce my update rate.
In fact, this does reflect what I see in my log data... after getting to 10485 mRad, the angle starts counting down again...
So I need to reduce my ADC range/rate, or reduce my measurement accuracy (like changing to tenth of a degree.)
No wonder my bot corrected in the wrong direction on evey second lap
If you move the multiply by 5L to the end of the expression, it should give you 5 times longer before it roles over.
  #309   Spotlight this post!
Unread 27-01-2008, 13:32
Kevin Watson's Avatar
La Caņada High School
FRC #2429
So I spent some time working on this yesterday, mostly just understanding how everything works (I wrote this code a few years ago). First, a bit of history: My first cut of the gyro code was included in the scripting code Rich Petras and I released in 2005 and the intent was to reset the gyro angle to zero, have the robot perform a turn, drive straight, reset the gyro angle to zero, execute another turn, etc. In this way, all turns are relative and I didn't need to worry about rollover.
Okay, so yesterday I modified the code to gain more headroom (ADXRS150 w/ default settings rolls over in just over five revolutions) and implemented a scheme where complete revolutions are detected, counted, and then subtracted from the total angle. In this way the number of revolutions is accounted for separately from the angle. The downside is that the code is somewhat bloated and convoluted. I guess I'd like to keep the status quo with additonal headroom and dump the loop counting code, but I'd like to get some feedback on what teams want.
-Kevin
Kevin Watson
http://kevin.org
  #310   Spotlight this post!
Unread 27-01-2008, 18:34
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by Kevin Watson View Post
...Okay, so yesterday I modified the code to gain more headroom (ADXRS150 w/ default settings rolls over in just over five revolutions) and implemented a scheme where complete revolutions are detected, counted, and then subtracted from the total angle. In this way the number of revolutions is accounted for separately from the angle. The downside is that the code is somewhat bloated and convoluted. I guess I'd like to keep the status quo with additional headroom and dump the loop counting code, but I'd like to get some feedback on what teams want.
-Kevin
Thanks for the background description. It helps in understanding how and why the code operates the way it does.
As for feedback;
Honestly, currently we don't have a need to keep track of heading for up to five revolutions. In fact, this year we will really only be expecting the code to track up to one and a half revolutions. So, as it is now, it will work just fine. On another note, I am curious as to the outcome of the question/observation PhilBot had when he posted this"
I think the problem is that GYRO_CAL_FACTOR is defined as 1000/1000, but the multiplication is being done AFTER the prior expression is cast to an integer... Therefore if ((((long)gyro_rate * GYRO_SENSITIVITY * 5L) / ADC_RANGE)) calculates to anything above 32 or below -32, then multiplying it by 1000 will cause the number to exceed the valid range of an integer.
I think the second to last bracket is misplaced... I think it should be:
return((int)((((long)gyro_rate * GYRO_SENSITIVITY * 5L) / ADC_RANGE) * GYRO_CAL_FACTOR));
Is there a problem with the Get_Gyro_Rate() function? We will be depending on it heavily this year, and need it to function correctly.
  #311   Spotlight this post!
Unread 27-01-2008, 20:17
FRC #2429
Yes, Phil caught an error that would cause the function to overflow if you rotated your gyro fast enough. This is what the fixed code currently looks like:
return((int)(((((long)gyro_rate * GYRO_SENSITIVITY * 5L) / ADC_RANGE)) * GYRO_CAL_FACTOR));
-Kevin
Kevin Watson
http://kevin.org
  #312   Spotlight this post!
Unread 27-01-2008, 20:31
billbo911's Avatar
-Kevin
Excellent!! We will modify the code accordingly until an updated version comes out!
Thanks again Kevin. Your work is appreciated more than I can express.
  #313   Spotlight this post!
Unread 27-01-2008, 21:54
Jon236's Avatar
AKA: Jon Mittelman
And here is some code to remap gyro values to the standard format
rev = temp_gyro_angle/3600;
if (temp_gyro_angle < 0)
gyro = temp_gyro_angle - (3600*(rev));
if (gyro < 1800)
gyro+= 3600;
if (temp_gyro_angle > 0)
if (gyro > 1800)
gyro-= 3600;
if (gyro > 1800)
gyro -= 3600;
Jon Mittelman
  #314   Spotlight this post!
Unread 28-01-2008, 20:01
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
We are trying to compile and down load the base 3.0 code using MPLab IDE 7.62 and the Upgrade version of C18 compiler to 3.10. We tried downloading to the 2006 and 2007 controllers (8722). However, we are getting a code error and the program light is flashing rapidly.
My question is a) can the 3.0 code work in the 2006/2007 controllers? If so, then what other situation may cause the program error to light and program light to blink rapidly?
Edited:
Found the problem. I had forgotten to uncomment the defines in ifi_frc.h; but I had uncommented everything else in the rest of the code. No error messages during the build, but immediately after the the download the controller was crashing.
Also, Kevin, thanks for the great work on the code this year.
D. Sean Kelly
Toltechs #499
MPLab IDE 7.62 C18-Compiler 3.10
  #315   Spotlight this post!
Unread 28-01-2008, 21:03
wcarr wcarr is offline
Engineer/Mentor
AKA: Bill Carr
FRC #0157 (Aztechs 157)
wcarr is an unknown quantity at this point
Just FYI, I believe that I have a single version of the code that will work with all robot controllers from 2004 on and can be built with C18 2.4 or 3.1. After seeing if I can improve the gyro integration code (per Philbot's posting above), doing some additional testing, and writing a bit more documentation, I should be able to release the code in the next few days.
-Kevin
Hi Kevin,
I'd like to add my thanks for the great work on the new framework.
We use the 8520 for small groups prototyping code. I know you are working on a set of code that will work for all controllers, but I was wondering if the message you have in adc.c:
* This version will only work with PIC18F8722 based robot
* controllers. You should use version 0.3 of this software
* with a PIC18F8520 based robot controller.
is still valid. And if so, how would I go about getting version 0.3 of the adc.[ch]?
Thanks!
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
