Go to Post If Andy asked y'all to stand on your head, would you do that, too? ;) - Madison [more]
Unread 21-01-2008, 17:48
JonathanLKS JonathanLKS is offline
Code::Blocks
FRC #0610 (The Coyotes)
JonathanLKS will become famous soon enough
Send a message via MSN to JonathanLKS
Codeblocks IDE
Team 610 uses the codeblocks ide instead of mplab to compile code for our robot. There have been some requests for it but I've been either busy or havn't checked chief delphi enough to respond so I'm releasing the entire thing here.
This specific version is designed to run on Kevin Watson's new code with mcc18 3.10. It also runs portably out of the box, just copy the contents of your mcc18 folder to the mcc18 folder in the codeblocks folder, put the entire folder on a flash drive or something, and you can code anywhere.
Just run the shortcut named CodeBlocks or the batch file portable_codeblocks.bat, don't run codeblocks.exe. All the batch file does is change your home directory temporarily to the settings folder when codeblocks starts up.
To load up code, make a new project, under User Templates select FRC Robot Code, and then just add all your .c and .h files, no need to add the .lkr or .lib files as long as they are in the same directory.
This is a relatively new version that I modified so I havn't tested it thoroughly.
You can download it here
http://rapidshare.com/files/85547669...locks.rar.html
or
http://robotics.crescentschool.org/CodeBlocks.rar
Team 610 [ Co-Leader | Head Programmer | Webmaster ]
We're attending: Greater Toronto Regional, San Diego Regional, Championship
Unread 26-01-2008, 22:29
Boku-Ni's Avatar
Boku-Ni Boku-Ni is offline
AKA: Hank
FRC #1289 (Gearheadz)
Boku-Ni is an unknown quantity at this point
Send a message via ICQ to Boku-Ni Send a message via AIM to Boku-Ni Send a message via MSN to Boku-Ni
Re: Codeblocks IDE
Hehe, I didn't think any other compiler beside MPLab could be used. Nice.
Programmers don't byte, they nibble a bit.
"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones." -- Albert Einstein
Unread 27-01-2008, 21:27
abrockhoff abrockhoff is offline
Team 11 Programming Captain
AKA: Alex Brockhoff
FRC #0011 (MORT)
abrockhoff will become famous soon enough
Send a message via AIM to abrockhoff
Re: Codeblocks IDE
Team 11 has been using CodeBlocks for the past couple years also, it's a great IDE and I suggest everyone checks it out. It's completely open source, and we've written a few plugins of our own for it.
Unread 28-01-2008, 17:44
Code::Blocks
Re: Codeblocks IDE
It seems this file doesn't work with Vista.
To get it to work follow these instructions
  1. Go to the settings folder
  2. Rename Application Data to Roaming
  3. Make a new folder named AppData
  4. Place Roaming in AppData
Unread 02-04-2008, 23:54
Boku-Ni's Avatar
AKA: Hank
Re: Codeblocks IDE
Mmm, I keep getting this error:
Error - could not find file 'C:\Users\Hank\Desktop\CodeBlocks\projects\hanks_r obot_code\ifi_frc_8722.lib'.
Errors : 1
Does anyone know how to fix? Thanks in advance.
Unread 03-04-2008, 00:05
laultima laultima is offline
FRC #1458 (Danvillans)
laultima is on a distinguished road
Send a message via AIM to laultima
Re: Codeblocks IDE
Are you using Kevin's Code? If so, then you need to move 18f8722.lkr as well as rename ifi_frc_8722_30.lib to ifi_frc_8722.lib and move them to C:\Users\Hank\Desktop\CodeBlocks\projects\hanks_r obot_code. Both of these are in the ifi_frc folder.
2007 Davis/Sacramento Regional Winner (100, 997, 1458)
2008 Davis/Sacramento Regional Gracious Professionalism Award Winner
Unread 03-04-2008, 10:37
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Codeblocks IDE
I would strongly recommend against this. Unless you're backing up your code to a hard drive somewhere on a regular basis. Flash drive are not a permanent storage solution. They can get lost, get corrupted, get rewritten too many times, or just plain die. Losing your robot's code due to a flash drive failure isn't going to be a fun thing.
IDE Bob22341 Programming 16 18-04-2007 12:10
Portable IDE Nitinol Programming 14 04-02-2007 03:23
MPLAB IDE rholokleolke Programming 13 08-12-2006 18:32
FIRST IDE? EHaskins Programming 19 14-07-2006 05:52
IDE buss Programming 2 08-01-2005 16:16
