Go to Post I'm not basing success on winning a regional. Success is learning by building the best system you can. In the engineering industries, the best system is the one chosen. - AdamHeard [more]
Unread 27-01-2008, 21:50
merybar's Avatar
merybar merybar is offline
AKA: Matt
FRC #0894 (Chargers Robotics)
merybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of light
Send a message via AIM to merybar
Autonomous Controller Board Switch
Anybody know where to purchase the materials for a autonomous mode controller board switch?
Unread 27-01-2008, 22:25
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
Re: Autonomous Controller Board Switch
If you don't want to make it yourself, AndyMark sells an assembled switch.
Otherwise, i'm sure you could buy the required parts including a DB15 connector and some switches (see the IFI schematic) at your local electronics store or somwhere like Mouser.
Unread 27-01-2008, 22:28
in between teams
AKA: Luke Van Oort
Huh? Do you mean a switch for putting the robot in autonomous mode (commonly referred to as an "autonomous dongle")? If so, you can get the necessary parts at your friendly neighborhood RadioShack/Fry's/whatever. You really just need a DB15 cable, multimeter (well, strictly speaking, it isn't necessary, but it is very useful), wire strippers, two switches, a soldering iron, solder, and something to house the finished product in.
Team 1219: 2009 - Mentor
Unread 06-02-2008, 09:13
SmithWest SmithWest is offline
FRC #2495 (Hamilton West Robotics)
SmithWest is an unknown quantity at this point
Anyone have ideas where to pick up the DB15 solder cup? Local Radio Shacks don't seem to carry it. I wanted to just pick one up rather than order a 1 dollar part online. I'm in central NJ. Thanks.
Unread 08-02-2008, 01:02
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
we made our own dongle using a single pole single throw swhich that shorted pins 8 and 5 on a DB15 connector. If you don't have a DB15 connector around another simple way of making the connection is to strip off the ends of a solid strand wire (maybe 22AWG) and short the pins on the DB15 female on the controller. Of course this is a little risky because you have to pay careful attention that you are shorting the correct pins to ground. You could damage the controller if you connect the wrong pin to ground.
Hope that this helps
Unread 08-02-2008, 01:06
FRC #2477
Radio shack should have them cuz im seen them there before. Maybe the specific one you went to ran out of stock. what you need is a single pole single throw switch and a DB15 solder cup connector or one that provides the crimp pins. Although not the best way, you can crimp the pins using a needle nose pliers. I think usually these connectors are in those connector drawers that they have.
Unread 08-02-2008, 05:43
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Last year I made one from a ~$5 joystick "Y" cable that I bought from Radio Shack and cut the end off it and used that by mounting it in a small box with switches.
I noticed a month ago that the Radio shack near me was closing these joystick "Y" cables out and I bought one off the clearance rack so I am not sure if they are still selling them or not but you might want to check out your neighborhood Radio Shack...
Also, I just searched the radio shack site and searched but this item did not appear, so you might want to go and ask them if the have any if you choose to go this route.
good luck
Unread 24-03-2008, 20:54
starsROBOTICS starsROBOTICS is offline
FRC #2276 (S.T.A.R.S)
starsROBOTICS is on a distinguished road
how do i figure out which pins are which. do i read it from left to right starting at the top or do i read up down up down?
Unread 24-03-2008, 23:05
The pin numbers are usually marked on the connector. They go 1-8 across the longer row, then 9-15 in the same direction across the shorter row.
Unread 25-03-2008, 08:04
lilBcos's Avatar
lilBcos lilBcos is offline
AKA: Kevin
FRC #2228 (CougarTech)
lilBcos is an unknown quantity at this point
we use the AndyMark manufactured one and it works very well
2009-Finger Lakes Regional #5 Seeded Alliance(thanks to GRR Jr. and Sparks)
2008- Buckeye Regional #3 Seeded Alliance (thanks to X-Cats 191 and GaCo 1629)
2007- Finger Lakes Regional Rookie All Stars
2007- Finger Lakes Regional Highest Seeded Rookie
2007- Finger Lakes Regional #1 Seeded finals alliance (thanks to X-Cats 191 and Moe 365)
Autonomous Controller Board Switch merybar General Forum 2 27-01-2008 12:54
Cool Controller Board jacobevelyn Control System 3 26-01-2008 13:13
pic: Autonomous Mode Switch Gary Bonner Robot Showcase 4 18-02-2005 21:58
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
