Go to Post A few years of stress is worth a lifetime of opportunity. - omegasis25 [more]
Unread 27-01-2008, 22:06
Gdeaver Gdeaver is offline
FRC #1640
pic: What is that black goo ?
Unread 27-01-2008, 22:08
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: pic: What is that black goo ?
Cool! That's one thing that our team hasn't played with yet, let us know how it holds up.
Unread 27-01-2008, 22:09
Éowyn Éowyn is offline
no team ((no team))
Éowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to behold
Um . . . hate to sound ignorant, but what is that black goo?
Unread 27-01-2008, 23:40
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Epoxy. (most likely)
Unread 28-01-2008, 08:26
FRC #1640
That black goo is System 3 epoxy and 1/2" chopped carbon fiber. I posted this to give an example of how to join the fiberglass pultrusions. I've seen allot of that green and Gray stuff on robots this year. The problem is most teams are using real thick heavy pultrusions. They use fastening techniques that are common for metal. The item in the picture Is our ball lift fork. Both pieces are 1/8" wall 2 and 1 ". 2 holes were cut in the 2 " piece and the 1"" piece slide through extending 1/4" on the back side. A 1/4" piece of wood was inserted in the 2" to form a cavity to epoxy. Believe me that joint is very strong. Other parts of the pultrusion would fail before the joint. Hope fully this will inspire other teams to think of other uses for pultrustion. Our entire arm will be made of them. All made with common hand tools. No fancy CNC.
Unread 28-01-2008, 09:31
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Awww... it's not laffy taffy?
I thought maybe Willy Wonka was one of your sponsors.
Unread 28-01-2008, 10:13
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
epoxy=miracle substance, IMO
Unread 28-01-2008, 11:20
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Would you epoxy instead of welding? Given the choice, would you epoxy the metal of your drive train frame? I'm of the opinion to weld metal together, but perhaps this is just as well; I've never experimented with it before.
We are trying to think of how to attach fiberglass to metal in ways that don't use heavy mounts: would this really work and stay durable for ~48 (most-case scenario) matches? If the mount broke, it'd be pretty devastating since the epoxy takes at least a day to completely harden.
GitHub
Unread 28-01-2008, 11:27
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The type of attachment method you use should depend on a lot of variables. For our robot frame we are using fiberglass channel, but needed a plate to cover the bottom for mounting stuff, and to make it more rigid, along with corner braces. We decided that using 1/16" aluminum sheet and 3/16" rivets would be the best way to do this.
The curing time of epoxy makes it pretty much out of the question for quick fixes at competitions, but in the assembly Gdeaver shows above, it is indeed very unlikely that the epoxied joint will fail. You have to use your judgement about how likely it is that a glued joint will fail in a way that you can't repair it quickly if needed, and think about other ways to set up the joint so that it will be more reliable.
pic: Black Pearl mtbkr5 Robot Showcase 8 24-02-2007 12:34
pic: guess what did that Scott Morgan Robot Showcase 11 09-05-2005 23:54
pic: Guess What Put That Up There? 13something Robot Showcase 6 15-02-2005 19:45
pic: 461's black frame Logan Byers Robot Showcase 11 11-02-2005 22:16
pic: What the heck is that? CD47-Bot Extra Discussion 17 03-04-2004 07:04
