Go to Post Yes, I try to win matches, but you don't want to disrespect opponents......just get on their nerves an awful lot! :D - Josh Goodman [more]
Unread 27-01-2008, 21:42
k4r3n2's Avatar
k4r3n2 k4r3n2 is offline
AKA: Karen
FRC #1525 (Warbots)
k4r3n2 is an unknown quantity at this point
Circuit breakers?
Many threads suggest replacing the 20-amp circuit breaker in the Spike leading to our compressor with a 25-amp self-resetting circuit breaker. Does anyone know where to buy these?
Thanks in advance!
Unread 27-01-2008, 21:45
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Circuit breakers?
I thought you could only use the one-time fuse included with the Spike or a 20A self-reset replacement.
Unread 27-01-2008, 21:48
EricH EricH is online now
Thanks in advance!
Don't do it. You'll have to go to a 20-Amp breaker as soon as the inspectors find you. From <R55>:
 If the compressor is used, the air compressor Spike relay power feed must be protected with a 20A fuse or 20A circuit breaker. No other electrical load can be connected to this breaker.
And <R67>:
The fuse on the Spike relay for the air compressor may be replaced with a 20 Amp Snap- Action circuit breaker.
(emphasis mine)
Unread 27-01-2008, 21:49
k4r3n2's Avatar
AKA: Karen
FRC #1525 (Warbots)
It's very possible that I'm just remembering the number wrong.
Either way, do you know where to buy a 20-amp Snap-Action self-resetting circuit breaker? I tried googling it but didn't really get anywhere.
Unread 27-01-2008, 21:52
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
You can buy extra breakers from IFI Robotics.
http://www.ifirobotics.com/ifi-store.shtml
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 27-01-2008, 21:59
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Is there a retail vendor for these other than IFI? It's been a while since I searched, but I feel like I looked for a long time over the off-season to find anybody else who carries them, to no avail.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 27-01-2008, 22:17
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
Use one of the same circuit breakers that you use in the ATC panel for the robot controller, etc. Many were in your Kit of Parts. Conveniently, they fit in the spike as well!
Unread 28-01-2008, 03:36
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Terminal Supply has the 40A Maxi breakers, as well as the standard ATC ones. Looks like their ATC ones are colored .. hmm ..
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Circuit Breakers for motors Kris Verdeyen Rules/Strategy 3 11-01-2006 21:56
circuit breakers.... archiver 2001 2 23-06-2002 23:58
Circuit breakers archiver 2000 8 23-06-2002 23:30
Circuit Breakers: Tripping Al Skierkiewicz Electrical 7 10-04-2002 12:40
Circuit Breakers ark_1230 Electrical 28 09-04-2002 23:16
