Go to Post Finish... what an interesting concept. I'm still hoping to do that to our 2003 bot. - Joshua May [more]
Unread 26-01-2008, 15:01
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
ReadSerialPortx Questions
When the function ReadSerialPortx is called does it actually read from the serial port, or does it read a byte from the input circular buffer?
If the ReadSerialPortx function does read from the buffer, I'm assuming the data from the serial ports is automatically stuffed into these buffers? As in, I don't need to write a routine to fill the buffers with data?
And finally, how large are the input and output ring buffers? I need to know how fast I need to retrieve data from them so overwrites don't occur.
TIA,
Nathan
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Unread 27-01-2008, 22:19
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: ReadSerialPortx Questions
The WPILIB manual states that it reads from the ring buffer. We use this function (in EasyC) - you don't need to do anything, other than to read the port ... no need to initialize it, just read it. If there is nothing in the buffer when you read it, you get 0 (null) character as a return value.
You will need to message Brad Miller for your detailed question about buffer sizes and the time required for incoming data to over-fill the buffer. You shouldn't have a problem with fast incoming data rates if you continually read the serial port in your While(1) loop - which can execute as many as 60,000 times per second in our experience.
Unread 29-01-2008, 21:25
Nathan's Avatar
Thanks for the explanation mluckham.
Nathan
3 Questions!!! (2/5/04) Andy Grady General Forum 11 05-02-2004 21:14
3 Questions!!! (2/4/04) Andy Grady General Forum 8 04-02-2004 20:52
3 Questions!!! (2/3/04) Andy Grady General Forum 16 04-02-2004 11:50
3 Questions!!! (2/2/04) Andy Grady General Forum 18 02-02-2004 22:18
3 Questions!!! (1/13/04) Andy Grady General Forum 21 14-01-2004 10:03
