Go to Post All I know is that last year in Philadelphi, our camera locked dead onto MOE (Team 365) and their flourescent green shirts during the matches. They might want to consider what would happen if they get pelted with balls during the autonomous period! :ahh: - Greg Marra [more]
Unread 26-01-2008, 17:42
Stephi Rae's Avatar
Stephi Rae Stephi Rae is offline
Lets play robots!
AKA: Stephanie Morrison
FRC #5803 (Apex Robotics)
Stephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to behold
Send a message via AIM to Stephi Rae
Servo shifting a dewalt
Team 1983 is wondering if it would be possible to use one PWM from the robot controller split into four, using sets of y-cables, to shift each of the four transmissions simultaneously using the servos. We are using the "Nothing But Dewalts" system and are looking for ways to make sure each motor/servo will shift at the same time.
Thanks!
~Stephanie Morrison (Hoag)~
Student - Team 1983 (2007-2008)
Mentor - Team 190 (2009-2012)
Mentor - Team 1983 (2013-2014)
Mentor - Team 1318 (2015)
Coach - Apex Robotics 5803 (2016-Present)
Unread 26-01-2008, 18:35
Re: Servo shifting a dewalt
I wouldn't rely on the PWM output of the RC to be able to drive four servos simultaneously. You'll get exactly the same control signal out of multiple PWM outputs if you command them to the same value, so I'd connect each servo to its own output and just set them in tandem. For example,
  pwm05 = pwm06 = pwm07 = pwm08 = 15;
Unread 26-01-2008, 22:32
Stephi Rae's Avatar
Lets play robots!
I will get this information to our programmers right away. Thanks so much!
Unread 26-01-2008, 22:39
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
you will also get more power to them if you dont split them....
Unread 28-01-2008, 01:03
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
It might also be a good idea to keep the servos on different ports so that you can tune each one individually to the right positions, like if your piano wire linkages are not all exactly the same, you may have to send different values to the servos.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 28-01-2008, 12:30
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Servo shifting a dewalt
Be cautious on how many servos are used, as they can drain the backup battery quickly if you shift a lot. We use a charging circuit now instead (custom circuit) as we have had problems with draindown using only two servos to shift. Would recommend you install a charging circuit that is powered from the main battery to eliminate that potential problem with the number of servos you plan on using.
AM servo delayed or no shifting haroony341 Technical Discussion 20 11-04-2007 12:31
Shifting transmissions: servo or pneumatics? gnirts Motors 8 15-01-2007 21:52
paper: Servo Vs. Pneumatic Shifting GMAdan Extra Discussion 1 04-12-2006 11:48
Dewalt Shifting Questions Ben Piecuch Technical Discussion 3 20-02-2006 13:40
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
