Go to Post If 100 people from ChiefDelphi all wrote one full article on something that they are an 'expert' in, FIRSTwiki would be even better. - artdutra04 [more]
Unread 28-01-2008, 12:11
programmr's Avatar
programmr programmr is offline
AKA: Face
FRC #0522
programmr is a jewel in the roughprogrammr is a jewel in the roughprogrammr is a jewel in the rough
Send a message via AIM to programmr
Program a motor to turn on and off every other second.....
Hello, i'm having a problem.... If someone could help, i would greatly appreciate it. In the user routines.c file, i need to make pwm01 turn on for 1 second and turn off for another second, then turn on for another second, and so on and so forth. I want it to be on p3_sw_Trig.... Does anyone know how i would do it? Please help... thank you very much.
Unread 28-01-2008, 13:14
GRS GRS is offline
FRC #1764
GRS is an unknown quantity at this point
Re: Program a motor to turn on and off every other second.....
Here's some untested code that should do what you're asking, basically this code toggles pwm01 between 0 and 127 every 44 loops, and makes pwm01 go back to off if the button is not pressed.
A static byte causes the compiler to not delete the data in a variable after it leaves a function, and "loops++" tells it to add 1 to the variable and store it back into itself, essentially saying loops = loops + 1
void code()
  static byte loops = 0; // which loop are we on?
  if (p3_sw_trig != 0)
    loops++; // add 1 to the loop counter
    if (loops <= 44) {
      pwm01 = 127; // motor off
    } else if (loops <= 88) {
      pwm01 = 0; // motor on
    } else {
      loops = 0; // go back to 0
  } else {
    pwm01 = 127; // switch not on, motor is off!
Unread 28-01-2008, 13:21
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
First of all, I'm getting confused which one you are -- ChrisR_522 or jax1488? And now programmr? jax1488 was asking the same question in this thread, but he thanked me for answering ChrisR_522's question in this thread. No biggie, but multiple names and duplicate questions are confusing at best and wastes time for sure.
Tom Line's answer here is a good starting point. Wrap that if block inside another if that checks for the trigger. Follow each true/false branch by yourself (make a flowchart if needed) to make sure it works.
And tell us all why your robot is doing this -- I think I speak for everybody here that we're curious what the robot is going to do.
Unread 28-01-2008, 13:49
programmr's Avatar
AKA: Face
FRC #0522
It's me using two members' names because i didnt have my own... sorry if i confused you. I'd like to thank you for the code given above. Theres only one thing though, it says syntax error....
void code()
{ IT SAYS THIS IS AN ERROR!!!
Do you know what could possibly be the problem? Thank You.
Unread 28-01-2008, 13:54
FRC #1153
Rookie Year: 1900
try
void code (void)
Unread 28-01-2008, 14:03
programmr's Avatar
AKA: Face
FRC #0522
hey sorry to keep bothering you guys, but i still says theres a syntax error at that same spot.
Unread 28-01-2008, 14:24
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
It would be very helpful to know what the error is...in fact, you should ALWAYS post the error.
Looks like, though, you might have a function without a declaration. So open up a header file (your team's, if you have your own library, but user_routines.h will work) and add in:
void code(void);
Or whatever you decide to use for the function's name.
What place are we at? ... TODAI!
Unread 28-01-2008, 14:56
programmr's Avatar
AKA: Face
FRC #0522
this is the error i get:
"G:\2005\test pulse\user_routines.c:231:Error: syntax error"
Unread 28-01-2008, 16:05
Chaos in a Can Chaos in a Can is offline
Joel Spadin
FRC #1736 (Robot Casserole)
Chaos in a Can is an unknown quantity at this point
Send a message via MSN to Chaos in a Can
Ah yes, the ever helpful "syntax error"...
Try replacing "byte" with "unsigned char". They mean the same thing.
I don't know if byte works with MPLAB.
Also, if you get a syntax error on the last line of a file, make sure to put an extra blank line at the end of the code.
2006 Xerox Creativity Award
2007 General Motors Industrial Design Award
2008 Judges' Award
2009 Chrysler Team Spirit Award
Unread 28-01-2008, 16:08
GRS GRS is offline
FRC #1764
Oh. Hehe. byte.. yea, that's supposed to be a char. (VB6 vs. C...)
Unread 29-01-2008, 06:42
programmr's Avatar
AKA: Face
FRC #0522
IT STILL SAYS : "G:\2005\test pulse\user_routines.c:232:Error: syntax error"
void code()
{ THIS IS LINE 232 HELP PLEASE....
static unsigned char loops = 0; // which loop are we on?
if (loops <= 44) {
} else {
} else {
Someone please help me try to get this issue resolved. Thank You
Unread 29-01-2008, 06:56
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
You can't have two else statements like that.
It's
if
else if
else
If you need it longer, it's
if
else if
else if
else if
else
Unread 29-01-2008, 07:32
Look for a missing semicolon or close brace on the line immediately before what you've shown us. If you don't see anything wrong, consider attaching the entire user_routines.c file so we can look through it.
Unread 29-01-2008, 07:41
programmr's Avatar
AKA: Face
FRC #0522
THANKS TO ALL FOR HELPING ME! YOU GUYS ARE GREAT!
Unread 29-01-2008, 09:25
Joel Spadin
Look at the code again.
It's lost its indentation, so it's hard to see, but the code is perfectly fine.
The second else belongs to the first of two if's.
I'm guessing the problem is not in line 232, but somewhere before that line.
The compiler was expecting something like a semicolon at the end of a previous line, but didn't complain about it until it found the start brace in line 232, which it wasn't expecting.
Look over the code just before "void code()".
2008 Judges' Award
Turn off outlining? Justin M. Inventor 11 01-02-2007 09:16
How fast does the Solenoids turn on and off? Generalx5 Robotics Education and Curriculum 2 26-01-2007 01:09
Anyone know how fast the Solenoids on the MINI RC can turn on and off? Generalx5 Control System 1 06-01-2007 07:39
Program machine to turn and stop CharlieWilken Programming 1 19-02-2004 12:50
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
