Go to Post you know you're going to meet someone important, so you put on your robotics team shirt. - NorviewsVeteran [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 18-01-2008, 23:51
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Gates Belt specifications
Does anyone know where to find performance and strength information for the KOP Gates Belts? I'm having trouble finding it on the Gates site.
PowerGrip GT2 belt, 5mm pitch, 9mm width.
Thanks!
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 19-01-2008, 08:40
Fab.Master's Avatar
Fab.Master Fab.Master is offline
FRC #0617 (Locomotives)
Fab.Master will become famous soon enough
Re: Gates Belt specifications
look here
http://www.gates.com/index.cfm?location_id=534
Unread 25-01-2008, 23:55
Drew Hopman's Avatar
Drew Hopman Drew Hopman is offline
Last Resort
FRC #0801 (HorsePower)
Drew Hopman is a jewel in the roughDrew Hopman is a jewel in the roughDrew Hopman is a jewel in the rough
Send a message via AIM to Drew Hopman Send a message via Yahoo to Drew Hopman
Anyone know where to find a copy of the gates information booklet that was in the KOP? I cant seem to find it anywhere, i want to look at some pictures of the lift that the built using their material....
Unread 28-01-2008, 13:53
jw2088 jw2088 is offline
jw2088 is an unknown quantity at this point
Quickest design information is from http://www.york-ind.com/ They have easily downloadable synchronous belt design software. Here is the bottom line:
The belts are very strong...take one you are not going to use and give it a static test. For FiRST applications the drive limiting factor will be the sprocket to shaft attachment, not the strength of the belt. You must have at least 6 teeth in mesh with the pulley and the belt must be tensioned so it will not jump teeth under the most severe load it might see in service. Also, do not crimp (bend the belt tighter than the 16 groove pulley) or you will break the belt tensile member. Also, catalog belt ratings are set up for drives lasting hundreds of hours in industrial applications. A FIRST robot application can be run at least 3 times catalog ratings. Once again the shaft attachment and the tension is the limiting factor.
Field Rug Specifications MaddyW Rules/Strategy 1 21-01-2006 17:44
Specifications TechnocratiK Programming 2 14-12-2005 16:48
Dashboard Interface Specifications archiver 2000 11 23-06-2002 22:43
Dashboard Interface Specifications archiver 2000 1 23-06-2002 22:42
The flood gates are open P.J. Baker General Forum 0 28-11-2001 08:47
