Go to Post Q: "What does your robot do?" A: "It collects data about the surrounding environment, then discards it and drives into walls" - tsaksa [more]
Unread 28-01-2008, 03:13
jjbarrow jjbarrow is offline
FRC #0441 (Reagan Devil Dogs)
jjbarrow is an unknown quantity at this point
pic: Team 441 Teaser
Unread 28-01-2008, 03:14
AdamHeard's Avatar
Lead Mentor
Re: pic: Team 441 Teaser
is painting the tanks legal?
Unread 28-01-2008, 08:28
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Isn't the paint just a non-functional decoration? FRC190 painted them to look like NOX bottles a few years ago, iirc.
I like the color scheme, and with mandatory bumpers this year, you can "almost" guarantee that the paint will still be there at the end of the season!
Bengineer
Unread 28-01-2008, 09:36
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
I suspect the inspectors would have to get a ruling from the Lead Inspector or FIRST. My gut feel is you shold have masked of the labeling so it can be seen. Otherwise, how else could they verify they are Bimbas?
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 28-01-2008, 12:41
The paint does fall under a decorational item and to verify that the reservoir tanks are still Bimba, there is a Manufacturer and model number etching on every tank. The etching can still be seen thru the paint to verify that are part of the FIRST kit.
Unread 28-01-2008, 13:06
Billfred's Avatar
Billfred Billfred is offline
The manual says:
<R92> Pneumatic components supplied in the Kit Of Parts (compressor, regulators, pressure
switches, cylinders, valves, fittings, tubing, etc.) can not be modified except as follows:
 The tubing may be cut.
 The wiring for the valves and pressure switch may be modified as necessary to interface
with the control system.
 Mounting and connecting pneumatics components using the pre-existing threads, mounting
brackets, etc., is not considered a modification of the components. Removing the pin from
the rear of an air cylinder is allowed as long as the cylinder itself is not modified.
Do not, for example, file, machine, or abrasively remove any part of an air cylinder. Consider
pneumatic components sacred. They must remain in “out of the shipping box” condition.
I'd Q&A it.
Unread 28-01-2008, 14:22
ScottieDo555's Avatar
ScottieDo555 ScottieDo555 is offline
Best of the best
AKA: Scott Donaldson
FRC #2219 (MegaHurts)
ScottieDo555 can only hope to improve
Send a message via AIM to ScottieDo555 Send a message via MSN to ScottieDo555
i really would like to find out if painting the cylinders is aloud. Any one know how i can find out?
Team MegaHurts 2219
BEST PAINTBALL FORUM - www.mcarterbrown.com - BEST PAINTBALL FORUM
Unread 28-01-2008, 14:35
AKA: Dana P. Henry
FIRST Q & A
Ask you team Main Contact to post, if it is not already.
Unread 28-01-2008, 20:32
Nick 1523's Avatar
Nick 1523 Nick 1523 is offline
Robot Manager
AKA: Nick Clark
FRC #1523 (M.A.R.S.)
Nick 1523 is an unknown quantity at this point
Send a message via AIM to Nick 1523
It looks pretty lol
sweet color scheme and I hope painting the cylinders is allowed because it looks really cool. also interesting way of putting the drivetrain, or at least part of the drivetrain, on the inside of the chassis I don't think I've ever seen that before.
pic: Team 60 Teaser Shawn60 Extra Discussion 3 20-01-2008 22:18
pic: Team 93 teaser 1 TLonghorns0593 Robot Showcase 7 08-02-2005 18:41
pic: Team 45 teaser Alan Anderson Extra Discussion 11 31-01-2005 12:30
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
pic: Team 66 Teaser CD47-Bot Extra Discussion 6 30-01-2004 11:31
