Re: Programming the last thing a robot does...
Are you sure they programmed it? Once you turn off the bot there's no more code.
I would'nt do this because it may be against the rulse. But if you have a function that overrides the stop command from the field controls, and in that function you could tell it to return back to how it was. Other than that I would just use a counter. All though it is your team's choice, that last second may be very useful for you guys, in the sense of the game. That last second might determine who wins the game. So if you really are bored, I would just make the operator of the robot be able to control that action, instead of doing it autonomously. |
Also, when I talk about "last second", I mean the last bit of code that executes, so no driver could react that quickly, and it wouldn't waste time during the match. |
Joey |
There may actually be a rule about this already that I am unfamiliar with if someone can quote one that would be cool, but if not a Q&A question may be in order. As far as moving everything back to a home postion after the match is over, if something is pnuematically driven you can always safely let the air out of the system, and move the components freely that are attached to them, but if it is a motor it may be more difficult unless you backdrive the motor manually (with the motors that can actually be backdriven by hand). Always keep a tether cable handy and in the worst case scenario bring out your control panel and your tether and put your robot in the home position on the field... or carry it off the field and do it there before returning to your pit if space is a huge issue. |
Hm... I would think if there was enough time for the software to contract the robot into a movable position, there would be enough time for the driver to get one last lap or hurdle in certain instances. Anyway, why don't you use a tether once the match ends? (Wait, this is against the rules, right? Never mind.) At least you could use a tether once you're off the field, but I guess that defeats the purpose.
Or maybe instead of a button triggering the contraction of the robot, a button that prevents it? The robot automatically folds up unless told otherwise in tight situations? Last edited by psy_wombats : 28-01-2008 at 18:14. |
| Who does the programming for your team? | EHaskins | Programming | 39 | 26-11-2006 16:49 |
| Who had the best robot last year? | slickguy2007 | General Forum | 16 | 05-11-2004 21:51 |
| The Last Chance to Dance for Your 2002 Robot | Wayne C. | Off-Season Events | 0 | 10-10-2002 22:03 |
| Posting our robot pics, the in thing to do | archiver | 2001 | 0 | 24-06-2002 00:56 |
