Go to Post What Delphi says doesn't matter. What the official Q&A says matters. - Tetraman [more]
Unread 28-01-2008, 15:15
Zultraranger Zultraranger is offline
FRC #0870
Zultraranger will become famous soon enoughZultraranger will become famous soon enough
End of the Match
At the end of the match, how do you release the air out of the pneumatic system?
Is it through programing or is it done mechanically?
Unread 28-01-2008, 15:17
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
Re: End of the Match
i would think by urself by the release valve.
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 28-01-2008, 15:18
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Open the valve manually.
Unread 28-01-2008, 15:25
FRC #0870
According to rules, at the end of the match before the teams go out and pick up their robots, the refs must be able to open the pneumatic devices with ease. Therefore, you must have to release the pressure outside of the arena, without touching the actual bot. Am I correct?
Unread 28-01-2008, 15:27
IndySam's Avatar
No, as long as you can go out on the field and release the air so they can retrieve the ball you're fine.
Unread 28-01-2008, 15:28
FRC #0870
Do you bet your life on that, because I believe I saw a rule on that?
Just to verify.
Unread 28-01-2008, 15:31
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
a release valve was provide just for that purpose. it is dont manually
Unread 28-01-2008, 15:33
FRC #0870
please speak english.
The Refs can use the manual release valve too, if necessary.
Just mark it's location well, so it's obvious where it is.
The only related rules I found were:
Originally Posted by 7.3.5.2 - Robot Operations-Robot Actions
<G45>
Arena Reset - ROBOTS must be designed to permit the release and removal of any TRACKBALLS from the ROBOT without being powered up after a MATCH.
Originally Posted by 9.6.4 - Field Reset Rules
<T13>
Field power to the ROBOTS will not be re-enabled after a match. ROBOTS must be designed to permit removal of TRACKBALLS or other ROBOTS without requiring activation of the ROBOT power system. Teams should design mechanisms that allow easy release of TRACKBALLS. At the discretion of the head referee or field manager, ROBOTS may be powered up and controlled via tether to collapse the ROBOT to permit safe and/or rapid removal from the field and transport to the pits.
Unread 28-01-2008, 15:35
IndySam's Avatar
Just to verify.
Well I'm only going to bet my life for God, Country or Family. That being said, here is the rule.
<G45> Arena Reset - ROBOTS must be designed to permit the release and removal of any TRACKBALLS from the ROBOT without being powered up after a MATCH. If a ROBOT violates this rule, the offending TEAM will be warned and requested to modify the ROBOT. If the modification is not made, the ROBOT may not be permitted to compete in future
MATCHES.
Unread 28-01-2008, 15:36
FRC #0870
MATCHES.
You are my hero.
end of match autonomous mode !aaaaa! Programming 23 15-12-2007 14:47
End of match ramp-bot question... AHS1599 Rules/Strategy 1 18-02-2007 12:34
pic: End of final match Ken Platteschor Extra Discussion 1 19-06-2005 19:01
End of match tethering DirtyBird213 Rules/Strategy 2 15-01-2004 20:29
End of Match Score SkitzoSmurf Rules/Strategy 1 10-01-2004 14:02
