Go to Post Were cargo shorts ever in fashion? I thought they were in the socks with sandals category. - AdamHeard [more]
Unread 28-01-2008, 19:51
darkdwarven's Avatar
darkdwarven darkdwarven is offline
AKA: Phantom
FRC #2348
darkdwarven is an unknown quantity at this point
Unhappy Switch Function Problems
I am using a switch function with MPLAB within the autonomous section fo user_routines_fast.c and the code I've written up does not seem to be executing...ever. For example, when I load the attached code, the motors attached to the PWM outputs only turn for 3-4 seconds and stop. I asked another team about it and their response was that the delay right above the while loop was the reason. I changed the value to 570 and the results were the same.
Do you think the numbers next to the "#define" section are the issue or does MPLAB hate us and the switch function alltogether?
Any and all help is appreciated!
Thanks in advance,
Team 2348.
Last edited by darkdwarven : 28-01-2008 at 19:52. Reason: The smiley did not match with the title
Unread 28-01-2008, 20:01
Re: Switch Function Problems
	static unsigned char delay;
  	static unsigned char direction;
	static unsigned char time;
An unsigned char's maximum value is 255. Since you want to use values greater then that for time, you should use an int.
Unread 29-01-2008, 03:16
AKA: Phantom
FRC #2348
Thanks!
It works perfectly now. Next thing to do, figure out where we went wrong with IR sensors and I'm sure there is a thread out there with the information I need.
I have nothing important to say here, thus I've wasted a few seconds of your life. Isn't that depressing?
printf, call of function without prototype problems cprogrammer Programming 3 11-05-2006 18:21
problems programming knob and switch caderader Programming 4 16-02-2006 16:45
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Problems programming a switch caderader Programming 2 18-02-2005 22:06
