Go to Post Scoring ringers is going to be like dating. While a select few will master it with relative ease, the vast majority will need quite a bit of time to refine their skills to an acceptable level. - artdutra04 [more]
Unread 28-01-2008, 21:03
Magnechu Magnechu is offline
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Team Role: Tactician
Magnechu has a spectacular aura aboutMagnechu has a spectacular aura about
Send a message via AIM to Magnechu
Pneumatic Tubing
1) Can we use the Pneumatic Tubing from last year?
2) Where can we buy Pneumatic Tubing?
Thank you!
Unread 28-01-2008, 21:05
Zultraranger Zultraranger is offline
FRC #0870
Zultraranger will become famous soon enoughZultraranger will become famous soon enough
Re: Pneumatic Tubing
We need pneumatic tubing please!
Unread 28-01-2008, 21:07
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
i believe so. i never saw rules against it. and they are both the same tubing just the orange is a bit stiffer. the psi was the same as last year so it should be fine. i know we are using last years for right now. and if they say at inspection we cant use it we are just gonna quickly swap it all out
Unread 28-01-2008, 21:10
FRC #0870
Yes, we need to make sure if the old tubing is legal. We need to have new tubing ordered so that we can replace the old tube.
Unread 28-01-2008, 21:16
Sam2197's Avatar
Team Role: Driver
i will go read through the rules and see if i come up with anything. but theoretically there should be no problems with using the old stuff. another random thing. my pressure regulator leaks. OH NOO
Unread 28-01-2008, 21:31
FRC #0870
thanks a lot. Good luck with finding the leak .
Unread 28-01-2008, 21:44
Sam2197's Avatar
Team Role: Driver
<R86>
 Prior year FIRST Kit Of Parts solenoid valves, and pneumatic tubing may be used in
addition to those provided in the 2008 Kit Of Parts. Their costs must be accounted for as
explained in Section 8.3.3 Budget Constraints.
woo and i just remembered in my rush to throw the regulators together that i didnt screw the plug all the way in on the unused port. silly me haha
pneumatic tubing Matt21q General Forum 1 19-02-2007 20:05
Using other pneumatic tubing Crtcalmss Pneumatics 3 18-01-2007 09:16
problems with pneumatic tubing in telescoping arm johnnymac4545 Pneumatics 5 25-02-2005 11:19
Pneumatic Tubing Question Ryan Dognaux Pneumatics 2 31-01-2004 20:23
Tubing pfortunejr Technical Discussion 6 11-01-2002 08:10
