Go to Post Heck, I gave several [E-Saver Lightbulbs] away as Christmas presents... - DonRotolo [more]
Unread 28-01-2008, 17:17
Setsanto's Avatar
Setsanto Setsanto is offline
FRC #1334 (OTHS RobOTics)
Team Role: Animator
Setsanto is a jewel in the roughSetsanto is a jewel in the roughSetsanto is a jewel in the rough
Send a message via MSN to Setsanto
Messed up water
Hi,
I know I've kind of been overusing help here the past few days but were a new team and im kinda supposed to be in charge. So, on that note, we have made a water material, which looks great. The problem is, only half of it does.
So, if anyone knows what my problem could be, help would be great. It is one plane, one material, and one light. Im using mental ray.
~Setsanto
2008 : GTA Regional 7th Seed, Quarters
2008 : Waterloo Regional 4th Seed, Quarters
2007 : GTA Regional 2nd Seed, Quarters
2007 : Waterloo Regional Quarters
Unread 28-01-2008, 18:19
richalex2010 richalex2010 is offline
AKA: Jake Alexander
FRC #0177 (Bobcat Robotics)
richalex2010 will become famous soon enough
Re: Messed up water
What sort of lighting are you using?
If you aren't already, I'd suggest trying the Daylight system with mental ray lights. That may eliminate some of the problems by producing a more even light (it simulates how the sky scatters the light, while still providing a direct light). Also, if you can, use final gather and global illumination (not sure about this in exterior day-lit scenarios, but it helps a lot in interior). That should increase the quality of the lighting a great deal.
-Jake Alexander
Unread 28-01-2008, 20:03
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Re: Messed up water
Another thing that might help is to move your camera up so it's looking down at a steeper angle. So you you dont see the horizon, or in this case a squared-off pond. Unless you want to show a squared-off pond.
Unread 28-01-2008, 21:20
Setsanto's Avatar
Team Role: Animator
Re: Messed up water
I will change the camera angle. Right now, I'm using just a spotlight with a very wide beam. I added some directional lights at the back to see if that would help but it didnt. I'm at my home comp right now, so I'm going to have to wait till tomorrow to try the daylight thing. Just one question. When I use MR with daylight, the daylight doesnt show up. Is it just a 3dsm8 thing?
~Setsanto
Unread 28-01-2008, 21:30
AKA: Jake Alexander
Re: Messed up water
It should be at a normal level of light (default light) with the mr lights (no need to mess with exposure control a lot). Could be that you have something configured with that for the normal exterior lights.
-Jake Alexander
Unread 28-01-2008, 23:13
Setsanto's Avatar
Team Role: Animator
Re: Messed up water
Ok, thanks
~Setsanto
Safe Water, Precious Water ebarker Fundraising 1 04-11-2007 18:43
Don't throw away the messed up parts- Donate them to Timmy!! archiver 2001 0 24-06-2002 01:03
