Go to Post Instead of prototyping with plywood and machining metal for the final version, they make their prototypes out of sheet metal and machine the final robot out of wood. :) - Chris is me [more]
Unread 28-01-2008, 21:45
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Re: Code Error when I try to program it
If you can, find another laptop with regular serial ports. It doesn't have to be powerful, we used a PII our first couple years. Make sure you use the new black cables in the KOP. Run IFI loader 1.10 *.hex files using a Flash Stick to verify correct operation.
It may be the restrictions the school district is placing on your user account. Industry and schools get a little carried away with security because some hackers love a challenge. Restricting serial ports is not unheard of.
It might also be interrupt errors within the laptop your using. Sometimes other devices use the same interrupts. This problem existed more with Win98, WinME, and some Win2K installations. XP doesn't care.
Also check the settings of the serial port. I think the settings are 115K baud, 8 data bits, 0 stop bits, no parity. Check the IFI Programming tips manual to be sure.
Download into the robot the default.hex file from FIRST. This should ALWAYS work if no changes have been made to it.
If the above does work, then you have a program error in your code. That Dreaded red light of death ( or orange in your case because it happened so fast) does appear quick if there is a While loop error in Initialization.
I hope this helps.
Team MARS = 1.523 AU from the SUN!
Jim E.
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
Error when compiling paulcd2000 Programming 2 21-01-2007 14:05
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
InterruptVectorLow error when we compile Redneck Programming 5 02-02-2005 22:57
Error when tried to delete thread... Matt Attallah CD Forum Support 4 18-01-2004 21:37
