Go to Post Is it January yet?? - Kevin Kolodziej [more]
Unread 28-01-2008, 20:49
calvin1631 calvin1631 is offline
FRC #1631
calvin1631 is on a distinguished road
Pressure optimization
We have a 2" x 24" cylinder and a 2" x 12" cylinder which are connected end-to-end. We are using 4 tanks and our compressor. I have looked at some calculations about pressure about how 60spi will create a 95 pound force in a two inch bore. I don't need all of this force and just need about 40 pounds, without sacrificing speed. Is the Festo solenoid more effective than the smc one? Also what would be the ideal pressure?
Unread 28-01-2008, 20:51
GRS GRS is offline
FRC #1764
GRS is an unknown quantity at this point
Re: Pressure optimization
The Norgren regulator will regulate the amount of PSI coming out of the air tanks.
Unread 28-01-2008, 21:14
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
i saw the fest as being really difficult to wire. so i just chose the smc ones. they are really quick too. i just used a 12 volt source to open and close it and it was an instant fire. so if you want something thats easy to wire go for that. (you have to wire the festo yourself). hopefully this helped you
Unread 28-01-2008, 21:32
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Some things to think about:
If you are using a 2" bore cylinder that means 60 psi is acting on 3.14 square inches giving you about 180 lbs. of force in the extend direction. Reducing the working pressure will certainly reduce the force. To get to 40 lbs. you would need to dial the regulator down to around 13 psi. However keep in mind that the less force you have, the slower you will go. Given a constant mass if force decreases, so does acceleration (F = ma). Whatever solenoid valve you use will not effect this. Also keep in mind that with 36" of 2" cylinder, you will use all of your stored air very quickly (assuming full travel).
Unread 28-01-2008, 22:16
FRC #1631
I forgot about newton's second law...
One last question, about how long does it take to pressurize the tanks up to 120psi?
Unread 28-01-2008, 22:40
AKA: Dan
Charging your tanks from 0 psi to 120 psi should take about 1 to 1.5 min. given a leak free system.
Unread 28-01-2008, 22:56
FRC #1631
Ok, Thanks!
Unread 29-01-2008, 12:10
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Keep in mind that the solenoids have a minimum working pressure. Anything below that pressure, and the solenoids won't work properly. Check the documentation to be sure, but I think the minimum pressure is 20 psi.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 29-01-2008, 13:33
There are a couple of design reasons you'd use one solenoid model over another, aside from the last second movement you get by virtue of the home position of the single solenoid valves when the robot is disabled.
The flow rate of the Festo is higher than the SMC.
The Festo requires a minimum 30 psi to operate.
The SMC requires a minimum of 20psi to operate.
Unread 29-01-2008, 17:06
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Can someone post or PM me the wiring for the Festo valve? I know it was supposed to be shipped in the KOP with the valves but ... well, needless to say we don't have that slip of paper anymore
___________________
- Tennyson, Ulysses
Unread 29-01-2008, 17:33
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
http://www.pneumaticsfirst.org/2006Game/FESTO2004.htm That is the same FESTO Valve that was given this year.
Pin 1 - Goes back to your main robot ground
Pin 2 - Goes to M+ on the relay
Easy as that. . .
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Automatic Spoiler Optimization Jared Russell Rules/Strategy 1 02-02-2007 22:16
general - optimization hanan Programming 2 20-01-2007 07:03
Pressure Pads Deltafrog Rules/Strategy 6 09-01-2005 00:27
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
