Go to Post They really should put warning signs at all entrances: "WARNING! FIRST IS CONTAGIOUS!" - KenWittlief [more]
Unread 29-01-2008, 01:41
jwkelly jwkelly is offline
AKA: Mr. Kelly
FRC #0585 (CyberPenguins)
jwkelly is on a distinguished road
New post-compile patch program for C18 HEX code . . .
All -- Team 585 has created a patch program in PERL that allows you to patch the compiled hex code with constants defined in an external file (i.e., constants not initialized at compile time). The upshot is that you can make a single build of the controller software, but maintain the flexibility of changing constants (e.g., calibration curves) as tuning and hardware changes dictate. Simply put, manage one controller build and a few text files of constants rather than several special builds that each have different constants defined in their source code.
I have enclosed the program but had to change the name from patchy.pl to patchy.txt to support the upload file types.
Please let me know if you find utility in this . . . um . . . utility.
Cheers-
jwk
Unread 29-01-2008, 01:50
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
Re: New post-compile patch program for C18 HEX code . . .
Very nice, thanks.
Unread 29-01-2008, 03:08
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Very cool. I'll give it a shot when I start tuning some of our control loops.
Unread 30-01-2008, 10:21
AKA: Mr. Kelly
Here are an example mdl.h and two mdl.txt files that we have tested with. Note that we have not yet loaded a patched file into the robot, but the process should work. Please let me know if the process works for you. I'll do the same once we get our robot loaded (probably later this week).
File Type: h mdl9.h (133 Bytes, 54 views)
File Type: txt mdl9.txt (325 Bytes, 62 views)
File Type: txt mdl12.txt (165 Bytes, 62 views)
New C18 3.0+ Compatible FRC Code Kevin Watson Programming 441 27-03-2008 15:30
MPLAB/c18 not creating a .hex file Cheezmeister Programming 7 15-02-2007 15:01
Hex code loader for the robot! paulcd2000 Programming 4 22-10-2006 01:58
New MS Patch.. very important. devicenull IT / Communications 0 05-01-2006 18:19
Can't Compile the Default Code pressurex1 Programming 4 25-01-2004 20:26
