Go to Post The battery will be mounted at the top, correct? There can be no other way. - Travis Hoffman [more]
Unread 28-01-2008, 16:59
DarKCroNo's Avatar
DarKCroNo DarKCroNo is offline
FRC #2670
DarKCroNo is an unknown quantity at this point
Using 2 motors in one toughbox
Our team has put together 2 CIM motors into the andymark toughbox, what we're wondering is if we should be connecting them both to 1 victor or 2?
Unread 28-01-2008, 17:02
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
Re: Using 2 motors in one toughbox
The rules state that you need 1 victor per CIM
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 28-01-2008, 17:03
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Each one has to be driven through it's own victor. so you'll need 2 speed controllers for each two motor transmission
-Dustin Benedict
Unread 28-01-2008, 17:12
DarKCroNo's Avatar
FRC #2670
oh okay thanks alot guys!
Unread 29-01-2008, 09:09
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
You can use a "Y" PWM cable to drive both Victors from the same PWM port on your Robot Controller.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Using DC motors Guy_E VEX 7 21-09-2006 12:58
using more motors Aren_Hill Motors 6 13-02-2005 17:44
using more motors Aren_Hill Technical Discussion 2 13-02-2005 15:52
Using two spikes for one motor supergrover Control System 6 24-02-2004 15:36
