Go to Post You'd be surprised how many teams don't read the rules period. - Koko Ed [more]
Unread 29-01-2008, 11:08
TechnocratiK TechnocratiK is offline
AKA: Patrick Diez
None #0296 (Northern Knights)
TechnocratiK is an unknown quantity at this point
PIC18F8722 TIMER2 Frequency?
So I was reading over Kevin Watson's gyro code (found here) and his code seems to suggest that TIMER2 has a clock frequency of 10 MHz. Is this external to the PIC on the IFI board? From the 18F8722 datasheet, it seems that the internal clock is at 8 MHz, not 10 MHz. What is the source for the TIMER2 oscillator, and what is its frequency?
TechnocratiK out.
Unread 29-01-2008, 11:22
Los Frijoles's Avatar
Los Frijoles Los Frijoles is offline
Stormin' Mormon
AKA: Kevin Cuzner
FRC #2062 (C.O.R.E.)
Los Frijoles has a spectacular aura aboutLos Frijoles has a spectacular aura about
Send a message via AIM to Los Frijoles
Re: PIC18F8722 TIMER2 Frequency?
The PIC in the controller is running at 40mhz and since it takes 4 clock ticks to execute 1 instruction cycle, it runs at 10 mips (million instructions per second). With a no prescaler, Timer2 runs at 10mhz. However, if a prescaler is set (recommended), it can run alot slower if need be. Look at the datasheet on Microchip.com.
The PIC in the robot runs off a crystal and the timer2 source is usually the instruction cycle clock.
Community Of Robotic Engineers 2062
Blender totally pwns 3DS Max...
My life is here and here.
Cuznersoft Hardware and Software Development
Unread 29-01-2008, 11:26
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
It is 10 MHz, I know because I developed some code programming the timers.
Here is the datasheet
http://www.ifirobotics.com/rc.shtml#Specifications
Unread 29-01-2008, 12:54
AKA: Patrick Diez
Awesome. Thanks a lot.
TechnocratiK out.
PIC18F8722 A1 Errata Sheet Released kmcclary Programming 14 20-10-2006 22:18
PWM Frequency Guy_E VEX 14 05-10-2006 23:20
PIC18F8722 Errata & High Priority Interrupts Joe Ross Programming 7 05-03-2006 00:14
PIC18F8722 - New 2006 RC MPU, 4x more program memory! kmcclary Programming 16 08-01-2006 14:22
